Wichita, KS Hand Saw Setup
« back to Hand Tools forum
Forum topic by GravelRoad posted 06-23-2017 02:15 PM 502 views 0 times favorited 10 replies Add to Favorites Watch
View GravelRoad's profile
GravelRoad
20 posts in 275 days
06-23-2017 02:15 PM
Anyone located in Wichita, KS who can do hand saw setups? I have a couple Pax saws that I think need to have the set adjusted. Thx
10 replies so far
View TheFridge's profile
TheFridge
8901 posts in 1394 days
#1 posted 06-23-2017 02:19 PM
What are the issues?
GravelRoad
#2 posted 06-23-2017 02:59 PM
The saw is binding. I tried some paste wax on the blade, but it didn’t help much.
View MrRon's profile
MrRon
4634 posts in 3151 days
#3 posted 06-23-2017 05:20 PM
A hand saw binds when the set of the teeth is uneven, or not set enough or set too much. A bent plate can also cause binding. I don’t believe most commercial sharpening services will do hand saws (too labor intensive and not profitable). This link may help. http://brfinewoodworking.com/hand-saw-sharpening/
GravelRoad
#4 posted 06-23-2017 05:48 PM
Thanks for the reference
View johnstoneb's profile
johnstoneb
2794 posts in 2080 days
#5 posted 06-23-2017 06:05 PM
commercial saw services will sharpen handsaw. Handsaw are machine sharpened and set just like circular saw blades just different machines Do a search I would guess there are several in Wichita.
-- Bruce, Boise, ID
TheFridge
#6 posted 06-23-2017 08:07 PM
You could probably find someone on here willing to do it for you if you can’t find something local.
View Davevand's profile
Davevand
51 posts in 744 days
#7 posted 06-28-2017 02:12 PM
If this is like the PAX that I bought, it needs to be sharpened. Mine looked like the teeth were punched out, set and never sharpened. I sharpened mine and it cuts fine.
GravelRoad
#8 posted 06-28-2017 10:40 PM
I removed the protective coating from the blade using acetone. This helped the binding a little. I also purchased a saw set, so I will attempt to adjust. Have to learn sometime – might as well give it a go!
View chrisstef's profile
chrisstef
17185 posts in 2914 days
#9 posted 06-28-2017 10:47 PM
A crosscut or a rip saw? Could we see some up close pics of the teeth?
GravelRoad
#10 posted 07-02-2017 10:06 PM
I have now cleared the protective coating, sharpened the saw, reset, and waxed the blade. It’s working perfect. I just wasn’t expecting all that work on these new Pax hand saws. Guess I was just spoiled with the out-of-the-box quality, fit, and finish of my Bad Axe saws! Thanks everyone for the comments/ideas.
