Jointer Co-Planar
Forum topic by Eric posted 06-23-2017 02:36 AM 401 views 0 times favorited 4 replies Add to Favorites Watch
View Eric's profile
Eric
221 posts in 2420 days
06-23-2017 02:36 AM
So I sent some time truing up my jointer tables. I then snug down all the lockscrews on the gibs. Went I change the table heights after, they go right back to their droopy positions. HELP! Do the gibs screws ever need replacing?
-- Eric
View TheFridge's profile
TheFridge
8908 posts in 1395 days
#1 posted 06-23-2017 02:41 AM
I doubt the gib screws play any part in the problem. Need to make sure it’s coplanar right after tightening screws. Or in the condition you would use the machine in.
View Loren's profile
9981 posts in 3557 days
#2 posted 06-23-2017 02:59 AM
There’s often a traveling bolt under each table,
in the center. If this is too loose the
tables may droop.
Are you sure there’s a pair of gibs in the
gap?
View Aj2's profile
Aj2
1273 posts in 1707 days
#3 posted 06-23-2017 04:31 AM
Not all joints can be adjusted.Jointers with Dt ways can be shimmed if they have been mishandled or left the factory in poor condition.
But this might limit your ability to adjust the table up and down.
There is a small chance you might be able to clean crud that built up from a previous owners use.To do this you will have to take the tables off.
Hopefully it’s a machine worth the trouble.
-- Aj
View Bluenote38's profile
Bluenote38
255 posts in 297 days
#4 posted 06-23-2017 03:03 PM
Not sure of the kind of jointer you have but first you should never have to replace the gib screws. If for some reason the gib screw are coming loose during operation (which they shouldn’t) back them out, clean them and add a 1/2 drop of Loctite 243 (Medium).
Way adjustment is accomplished (though I think you’ve done this) by loosening the gib screws and the locking screws. Back them of by a full turn and wiggle the table. Screw them back down hand snug which should take out the play in the table way. If not then apply a 1/4 turn and try again. Table should move freely up and down the way but not side to side. Tweak the gib screw until there is no side to side.
If that doesn’t work look at the clamp or bracket holding the table hand wheel in place (or maybe start here?). These are fragile (machined castings) and during moves most folks grab the I/O tables and lift. It puts a lot of stress on the bracket and they fail when they do fail the table will droop.
Pic is from a 1994 Craftsman 6” I just finished rebuilding. It is the same as the Rigid 6000 series and almost every other 6” jointer built since 1985. Most 8” look the same but bigger.
-- Bill - Rochester MI
