How do I make this cut
Forum topic by isu1977 posted 06-22-2017 10:13 PM 1450 views 0 times favorited 33 replies Add to Favorites Watch
View isu1977's profile
isu1977
44 posts in 3076 days
06-22-2017 10:13 PM
Any idea how I would make these cuts? Four cuts, same on each side.
-- Cy - Des Moines, IA
33 replies so far
View firefighterontheside's profile (online now)
19454 posts in 2060 days
#1 posted 06-22-2017 10:15 PM
I think we’re gonna need a bigger picture.
View shipwright's profile (online now)
shipwright
8166 posts in 3001 days
#2 posted 06-22-2017 10:35 PM
With the appropriate jig they could be cut on a table saw sideways. (like cove mouldings)
Just a thought, there is undoubtedly an easier way.
View Gilley23's profile
Gilley23
489 posts in 585 days
#3 posted 06-22-2017 11:55 PM
Two pieces of rails cut on a bandsaw with the desired curve (cut both at the same timeso that they’re the same) and make a router sled. Make a jig with the rails. I actually think that this would be super easy.
View Loren's profile
10477 posts in 3851 days
#4 posted 06-22-2017 11:56 PM
My guess would be it was done on a lathe
and then cut square.
You can devise a router jig to carve a dish.
View JayT's profile
JayT
5961 posts in 2415 days
#5 posted 06-22-2017 11:59 PM
My first thought was that it was done on a lathe, as well.
View TheFridge's profile
TheFridge
10752 posts in 1689 days
#6 posted 06-23-2017 12:19 AM
Lathe
View jbay's profile
jbay
2893 posts in 1103 days
#7 posted 06-23-2017 12:30 AM
Does it not go to a point in the center?
Gilley23
#8 posted 06-23-2017 12:39 AM
- jbay
Yes it does.
Make a router sled!
View sawdustdad's profile
sawdustdad
366 posts in 1088 days
#9 posted 06-23-2017 02:16 AM
Probably router and a sled is easiest way.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View jbay's profile
jbay
#10 posted 06-23-2017 02:41 AM
Radial arm saw.
Turn the blade sideways.
Make a jig to hold the work piece at an angle.
Make cuts lowering the saw blade 1/8” at a time.
Something like this:
View Woodknack's profile
Woodknack
12431 posts in 2583 days
#11 posted 06-23-2017 02:57 AM
It’s turned on a lathe, cut apart, and glued back together. Similar concept to inside out turning.
View jbay's profile
jbay
#12 posted 06-23-2017 03:37 AM
It s turned on a lathe, cut apart, and glued back together. Similar concept to inside out turning.
- Rick M
I can’t picture it. (not sayin it aint so, just can’t see it )
View Mike_D_S's profile
Mike_D_S
496 posts in 2418 days
#13 posted 06-23-2017 03:54 AM
Check out the router jigs for making the scoop cuts for seat bottoms. Basically a two axis sled. The X axis is the U and the Y axis is a wedge.
When the sled is all the way down the Y axis, you go left and right in the X axis U establishing the nice curved cut side to side at the edge. Then you start moving up the Y axis wedge while going back and forth in the U.
So basically you are cutting a climbing U and at the top of the wedge in the middle the bit basically lifts off the piece when the router is in the bottom of the U.
Rotate the piece and repeat for all the sides, resulting in the four way closure in the middle and each edge having the gentle curve corner to corner.
Mike
-- No honey, that's not new, I've had that forever......
#14 posted 06-23-2017 04:05 AM
It’s hard to tell from the picture because it’s
so small. If it is the shape shown in Jbay’s
drawing, then it could also simply be carved
out with power or hand tools. Perhaps it
way shaped on a the end of a belt sander.
Woodknack
#15 posted 06-23-2017 04:38 AM
- Rick M
I can t picture it. (not sayin it aint so, just can t see it )
- jbay
Cut diagonally into 4 pieces and turn them around. Think segmented turning.
If you turn a square piece on a lathe, you get something like this:
Make 2, cut them diagonally and turn them around so the outside corners become the center. The bottom probably wouldn’t be curved, it could be flat.
showing 1 through 15 of 33 replies
