Need help with lathe tailstock.
Forum topic by Russ posted 893 days ago 916 views 0 times favorited 4 replies Add to Favorites Watch
View Russ's profile
Russ
354 posts in 1245 days
893 days ago
Topic tags/keywords: lathe
So I’m not sure if I made a good decision here or not. But basically I picked up a Buffalo Brand lathe (WL-6) for $60. However the tailstock is not complete thus why I offered less than the $75 wanted. I’m pretty new to lathes and I don’t understand what is missing and I cannot find anything about this on the lathe. I’ve removed the tailstock screw from the tailstock and re-attached the head that was on the tailstock. Any help would be greatly appreciated.
-- Russ
View Mark Shymanski's profile
Mark Shymanski
3966 posts in 1881 days
#1 posted 871 days ago
Hmmm, wish I could help maybe some other LJs will see this as it rises to the top again.
Can you compare what you have to a similarly sized lathe and figure out what you have and what you don’t?
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
View Lochlainn1066's profile
Lochlainn1066
138 posts in 946 days
#2 posted 870 days ago
How old is it? If it’s 50’s or earlier, try Old Wood Working Machines, www.owwm.com
Lot of guys there in the forums with knowledge of old machinery, wouldn’t hurt to ask.
-- Nate, thegaragestudio.etsy.com
View KayBee's profile
KayBee
896 posts in 1415 days
#3 posted 870 days ago
Tool King used to sell buffalo brand machinery. They have their own ‘house brand’ now. Don’t know if it’s from the same factory as harbor freight or not. Might try looking closely at some of knock off brands though.
-- Karen - a little bit of stupid goes a long way
View Russ's profile
Russ
#4 posted 870 days ago
Through some investigation and the help of a guy from SMC I was able to obtain a tailstock from a HF lathe that is nearly identical. Now I just need to get some space cleaned up to do some turning.
-- Russ
