| Forum topic by ClayandNancy | posted 896 days ago | 613 views | 0 times favorited | 6 replies | ![]() |
896 days ago |
I have a chance at a Grizzly 3 HP DC, it is the one with 2 upper and 2 lower bags. I would add the Wynn filters to it. Anyone have any experience with this model? |
#1 posted 896 days ago |
I see you mention the Wynn Filters, so i’m guessing you’ve read Bill Pentz? If so, he recommends at least a 5HP motor coupled with a 16in impeller for 800CFM at the tool to collect all the fine dust… -- if you can't light a $100 bill on fire and watch it burn, you're in the wrong hobby. |
#2 posted 896 days ago |
This is not a cyclone, but I am going to make the Thien separator to put in front of this DC. Just wondered if anyone had experience with this DC before I fork over $250. |
#3 posted 896 days ago |
Hey Charlie, I’m taking your advice that you gave me on the Phil Thien forum. I’ve been looking at this 3HP unit at reseller for over a month. They originally wanted more than what a new unit would cost but have recently come down to $250. If this will work with a 6” permanent system I’ll nab it. Do you think going up to 8’ with the pipe and then branching off a trunk line to all the different tools would be OK. |
#4 posted 896 days ago |
I ran a 20 amp 220 circuit 12 gauge wire to where a Grizzly 2HP was hopefully going but I’m unemployed so that dream didn’t happen. I believe this unit needs a 30 amp circuit, so I will have to run a 10 gauge wire to that spot. I’ll reroute the 20 amp for something else. Thanks for your help. |
#5 posted 896 days ago |
dont forget that with 2 upper filters you’ll need 2 replacement Wynn filters which will jack the price up considerably which might put the final price so that it could be just worth getting a new cyclone from Grizzly. I’m not sure what the final numbers are -but my point is you might want to run all those numbers now and see what you get before investing time money and frustration going the lesser path. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#6 posted 895 days ago |
PurpLev The Wynns are $100 a piece and $150 for the polyester spun. You do make a point, the same DC with the filters isn’t that much more and they have the flapper. The other thing is I could wait to get the filters when I have money later on. Charlie see what you mean, probably need a 55 gal drum to use for a separator. I do have some space I could sacrifice and I have 12” ceilings so lifting it up wouldn’t be a problem. |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
