| Forum topic by TomFran | posted 923 days ago | 1852 views | 0 times favorited | 23 replies | ![]() |
923 days ago |
Topic tags/keywords: heater heaters shop heat shop heaters propane heater electric heater
Fellow LJ’s, I have a small shop, and I live in the south, but from time to time I need some heat to take the chill off. I presently have a 1500 watt electric space heater. It works OK, but what I was wondering is if a small propane heater (15K BTU) might heat the shop up quicker and better. I welcome your thoughts and experience on this matter. Do you think the propane heater pictured would be a better and more efficient source of heat? Thanks in advance for your input! -- Tom, Surfside Beach, SC - Romans 8:28 |
23 replies so far
#1 posted 923 days ago |
hey tom…nice to see ya..i think having a heater that blows your heat might be best…the radiant ones i think only do well in that they heat a close up area…unless its a large heater… i worked in a shop long ago that had a radiant heater on the ceiling…it went the length of the shop..and it did well…but it was big…ive got a wood stove myself..and it does really well, but my shop is not insulated…but that will change over the next year…im tired of being cold during these cold snaps..i too am in the south…central alabama…good luck with it…and take care…grizzman -- GRIZZMAN ...['''''] |
#2 posted 923 days ago |
Hi Tom, I have both heaters you have pictured, and also a kerosene heater. None of them do well unless you are within five feet of them when its really cold. I would get a larger propane or kerosene salamander style that has an electric fan. Ive used them in other garages and they really put out the heat. my next purchase hopefully. Good luck |
#3 posted 923 days ago |
I guess I am fortunate that I live much further south in southern Texas because I use the same 1500w electric space heater for a couple of hours and then just work in the resulting 60-ish temps in my 24’x30’. FWIW, I never cared for the propane/CO pollution in closed spaces and would opt for a wood stove before running propane. However, talk to me in the summer when I am B&M-ing about the 100 degree temps in the shop… ;-) -- HorizontalMike -- "Woodpeckers understand..." |
#4 posted 923 days ago |
Tom, The only thing I would suggest is that you look at vent free propane heaters. http://www.heatershop.com/vent_free_heaters.html You don’t want to run any fuel fed device in a closed space without ventilation. Of course who wants to turn on the heater and have to open a window so they don’t succumb to CO poisoning? The vent free models are the way to go. Good luck! |
#5 posted 923 days ago |
I’ve been using a $100 30k btu propane heater in my shop for about 5-6 years. It heats up quick and then I turn it off for a while. You can find them at any home store. |
#6 posted 923 days ago |
I’m in Nebraska and have an insulated shop, I’ve been running a small 600w oil filled heater (looks like an old fashioned radiator) and that has been keeping the shop about 50F. When I go out to work I run one of those quartz infrared (little boxy ones) and that brings the temp up to about 60-65 in 30 minutes or so. Comfortable for working so far. Not sure what will happen when things get really cold and snowy here. -- Jim, Nebraska |
#7 posted 923 days ago |
I use propane to heat my garage. Problem is I live in central Illinois and it gets cold! Propane heaters go through lots of propane and can get costly very quickly. |
#8 posted 923 days ago |
Usually I use my 1500 watt oil filled radiator. I feel it is safer than the propane heater. But I DO have a propane heater. Mr. Heater Portable Buddy model. A 9K BTU model that will drive the chill right out of the shop in a hurry. I am loacated in coastal Texas, so my weather isn’t too terribly cold compared to say New England or CaƱada. I will say this. Over the last year, I insulated the ceiling, and insulated and sealed both overhead doors, and I have yet to do need anything beyond the radiator, and even that is making things too warm most of the time. If you can, I would insulate first, THEN heat… It was 35 deg F outdoors the other morning, and without the heat on it was 67 in the shop. The heater QUICKLY takes up over 72 and in to some uncomfortable territory… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#9 posted 923 days ago |
I lived in Tennessee and my garage was heated with a larger Farm and Fleet gas heater. It was awesome. -- keeping myself entertained |
#10 posted 923 days ago |
JimNEB and dbhost, I actually have one of those 1500 watt oil filled radiators along with my fan-driven one. Which do you think work the best, the fan-driven electric heaters or the oil filled radiant type? -- Tom, Surfside Beach, SC - Romans 8:28 |
#11 posted 923 days ago |
Farm and Fleet gas heater caused a lot of potato house on fire around here they don’t use them any more. |
#12 posted 923 days ago |
This what I use … http://lumberjocks.com/reviews/1161 As a matter of fact, it has been on for about 10 minutes, so my shop should be toasty warm … gotta GO! —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#13 posted 923 days ago |
I have a 220V heater like TheDane. I use it to heat the shop up fast. Then I have a radiant heater to hold the heat once it gets where I want it. A ceiling fan on low helps move the heat off the ceiling. The main thing you need to do is have your shop well insulated. The other morning it was below zero and within an hour the shop was at 65 degrees. I turned off the 220 heater and used the radiant heater and fan the rest of the day. Keep warm! God Bless -- Mc Bridge Cabinets, Iowa |
#14 posted 923 days ago |
Thanks for all the great comments!!! I appreciate your input. -- Tom, Surfside Beach, SC - Romans 8:28 |
#15 posted 923 days ago |
TomFran, I use a 1500 watt oil filled radiator, in addition to having a larger HotDawg heater in the shop. The oil filled heater makes a huge difference, so the other heater rarely runs. I live in cold country and my shop is well insulated, so your miileage may vary depending upon how well insulated your shop is. |
| Forum | Topics |
Woodworking Skill Share
8850 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2104 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
