MDF use?
Forum topic by zipmac22 posted 06-20-2017 10:06 PM 464 views 0 times favorited 7 replies Add to Favorites Watch
View zipmac22's profile
zipmac22
20 posts in 755 days
06-20-2017 10:06 PM
I’m putting up trim around the garage door opening. I found some Finished Elegance MDF which is listed for interior use. If I seal the ends can the MDF be used outside? I plan on painting it too, so the boards will be sealed up pretty tight. Thanks!
7 replies so far
View ScottM's profile
ScottM
597 posts in 2049 days
#1 posted 06-20-2017 10:27 PM
I wouldn’t use it for that. It will just soak up any water and swell then fall apart.
View builtinbkyn's profile
builtinbkyn
1963 posts in 843 days
#2 posted 06-20-2017 10:31 PM
Yeah not for exterior use. As Scott said, it will soak up water, swell and fall apart in short order no matter how you try to seal it up.
-- Bill, Yo!......in Brooklyn & Steel City :)
View Madmark2's profile
Madmark2
379 posts in 491 days
#3 posted 06-20-2017 10:38 PM
MDF is contraindicated in damp to wet locations. It will swell & dissolve over time in high humidity without direct liquid contact.
M
View Desert_Woodworker's profile
Desert_Woodworker
1308 posts in 1117 days
#4 posted 06-21-2017 04:31 AM
I am not surprised by the comments above, but there is a MDF product; MEDEX. That is for exterior use; Exterior sign companies use it. I use it (see my projects)
-- Desert_Woodworker
View TheFridge's profile
TheFridge
8846 posts in 1388 days
#5 posted 06-21-2017 04:45 AM
Regular mdf definitely not.
9934 posts in 3550 days
#6 posted 06-21-2017 04:49 AM
MDF is almost waterproof on its faces. I have
a piece of MDF off a tool stand that has been
kicking around outside on the ground for
several years now and it is in better shape
than I would have expected. It certainly hasn’t
crumbled like wet particleboard will.
If you seal the edges well perhaps MDF will
hold up outdoors for awhile. But I would
be prepared for the material to fail sooner
than later.
View MrUnix's profile
MrUnix
6330 posts in 2101 days
#7 posted 06-21-2017 04:50 AM
- Desert_Woodworker
I’m sure it’s being used as you describe… but from their web site it says:
Limitations: Medex® is not suitable for structural applications, exterior siding or exterior trim
