Clamping Beam
Forum topic by bill1608 posted 06-20-2017 09:39 PM 896 views 0 times favorited 4 replies Add to Favorites Watch
View bill1608's profile
bill1608
12 posts in 1197 days
06-20-2017 09:39 PM
I made this clamping beam with an 8” x 8’ H-beam mounted on some old Oliver lathe legs. So handy. An H-beam, unlike an I-beam, is flat on top like a plate and fairly common, so works very well for clamping. In the photo, I drilled alignment holes for nails and then removed the nails 10 minutes later. Makes it easier to keep things aligned when clamping. I have other plans for the clamping beam, like a circle cutting router attachment.
View fivecodys's profile
fivecodys
1017 posts in 1658 days
#1 posted 06-20-2017 10:12 PM
Very clever sir! That beam must weigh a ton!
-- There' are two theories to arguin' with a woman. Neither one works.
View isotope's profile
isotope
172 posts in 1646 days
#2 posted 06-21-2017 12:19 PM
I think this is a great idea. Very clever. Well done.
View dday's profile
dday
153 posts in 1452 days
#3 posted 06-21-2017 12:43 PM
And it can double as a battering ram when your daughter locks the bathroom door…. :)
That is one unique way to make sure a glue up is straight and flat.
bill1608
#4 posted 06-21-2017 11:57 PM
The beam is 10” high and about 315 lbs. The legs are maybe another 100. I bought the beam at a supplier and was surprised at how flat and accurate it is. It is about 0.010” out of flat across the 8” width. Good enough for most woodworking purposes. My previous version was 6” x 6’ long and I put a thin epoxy later on top to make it perfectly flat. I might do the same with this one. I would grind it, but that doesn’t work, warps steel beams. Beams have good beam strength, but they are not torsionally stiff. I can tweak it with the leg levelers to remove any twist. The dolly under the beam can be rolled away after the levelers are lowered.
