Fasteners, what works best
Forum topic by sreilly24590 posted 06-20-2017 01:27 AM 963 views 0 times favorited 17 replies Add to Favorites Watch
View sreilly24590's profile
sreilly24590
138 posts in 672 days
06-20-2017 01:27 AM
As I get the shop set up and build cabinets, out feed table, router table, and so on I’m going through a ton of screws. Mostly #8 – 1-5/8” through 3”. The local hardware store is a bit expensive buying in 1 pound boxes. I have a nearby Fastenal Store that I plan on visiting tomorrow and they have these Phillips/Square wood screws in larger boxes for far less per screw. So for you seasoned woodworkers, what your choice in fasteners? Favorite supplier? I just did discover McFeely’s and ordered some “7MM X 50MM RTA CONNECTING SCREW QTY: 100” which are hex head fasteners described in an out feed table plan I’m using.
Steve
-- Steve, Virginia
17 replies so far
View papadan's profile
papadan
3584 posts in 3608 days
#1 posted 06-20-2017 01:32 AM
I buy 5 lb boxes at the home stores, HD and Lowes.
View waho6o9's profile
waho6o9
8539 posts in 2817 days
#2 posted 06-20-2017 01:37 AM
Spax:
or
GRK:
View KelleyCrafts's profile
KelleyCrafts
3405 posts in 979 days
#3 posted 06-20-2017 03:39 AM
I’m with Waho. I almost exclusively use spax unless there’s a specific need for something else.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
papadan
#4 posted 06-20-2017 03:42 AM
I’ve never seen the Spax screws.
woodbutcherbynight
5837 posts in 2649 days
#5 posted 06-20-2017 03:46 AM
I like the spax, but the HD ones are not too bad for general work like framing and such. The 1lb boxes seem to disappear rather quickly so like papadan said 5lbs is the way to go. Especially if you are using them up quickly. Of course this does mean you now have to find a place to store all these nice screws. Lots of good ideas here on the site for storage, here was my solution:
runswithscissors
2928 posts in 2265 days
#6 posted 06-20-2017 04:00 AM
The combo square/phillips screws seem all wrong to me. When a phillips cams out, you’re left with a hole that looks like the square drive. And there’s no guarantee that square drives won’t cam out too. Give me one or the other, but I prefer the square drives. And the others mentioned are even better, of course.
KelleyCrafts
#7 posted 06-20-2017 04:33 AM
Most of the spax one use torx bits. I like that. Usually have good luck with those.
Dan, I buy Spax at the HD. I bought 5lb bins in a couple sizes for jigs and and shop pieces and am still using them. I use 1 lb boxes for ones that I don’t always use. I don’t use screws usually for many projects but have no problem for most shop furniture or jigs.
KelleyCrafts
#8 posted 06-20-2017 04:39 AM
Storage….here’s an outfeed table which was my first project for building out the shop what seems like forever ago. It’s done poorly and used to have a shelf. Was a waste of space. So a long time ago. I built out sliding drawers and buckets for those to store this kind of thing.
View Woodknack's profile
Woodknack
12468 posts in 2620 days
#9 posted 06-20-2017 04:47 AM
I’m not using as many screws as a lot these guys, not enough for cost to be a concern, but have settled on Spax or GRK. Most common size for me is 1-1/4”. After that probably 2” and 3”.
View Madmark2's profile
Madmark2
409 posts in 828 days
#10 posted 06-20-2017 05:50 AM
Screws?
I just use what comes with and seldom have to buy.
M
View BenjaminNY's profile
BenjaminNY
134 posts in 1642 days
#11 posted 06-20-2017 10:27 AM
The spax or GRK screws seem to hold just fine and they don’t strip easily.
View Slider20's profile
Slider20
119 posts in 761 days
#12 posted 06-20-2017 11:26 AM
As many have said, Spax or GRK, I get them at Home Depot. I don’t use a ton of Screws so I don’t buy the really big contractor boxes.
View dhazelton's profile
dhazelton
2805 posts in 2536 days
#13 posted 06-20-2017 11:33 AM
I don’t know where you live but there are chains like Ollie’s and Big Lot’s that have drywall screws for a lot less than the $6-7 a pound the box stores charge. Selection is hit and miss though.
waho6o9
#14 posted 06-20-2017 12:04 PM
Depending on the application I use drywall screws as well. they’re quick and
efficient.
sreilly24590
#15 posted 06-20-2017 01:19 PM
Thanks for all the replies. I like the idea of the SPAX screws and will definately look into those. As is the case for me, I usually don’t use that many but in the time of getting the shop set up and building the out feed table, cabinets for storage, assembly tables, lumber rack, and the just completed sheets good rack, I’m lo king at a ton of screws. Of cousre so far the sheet good rack and cracasses for 2 doulbe wall cabinets are as far as I’ve gotten. Well add the cordless drill/nailer organizer to being done as well. It’ll be 6-12 months before I get it all set up. I hope the wife never wants to sell the house!
-- Steve, Virginia
