Drill press table
Forum topic by vintagecraftsman posted 06-19-2017 07:53 PM 415 views 0 times favorited 1 reply Add to Favorites Watch
View vintagecraftsman's profile
vintagecraftsman
12 posts in 560 days
06-19-2017 07:53 PM
I have a bench top drill press with an adjustable table that raises and lowers, tilts, and rotates 360 degrees around the column. I would really like to make a table and fence for it. My question is what is the best way to do so and ensure that everything is square to the bit? As I said my table current rotates 360 degrees and it is also a round table not square. Thanks in advance for the advice.
-- Vintage Craftsman
1 reply so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3031 days
#1 posted 06-19-2017 08:31 PM
Your DP should also have a tilt function/adjustment. Between that and your to-be attached DP table, you should be able to set that using nothing more than a square.
FWIW, personally I chose this as my DP table:
http://www.grizzly.com/products/Drill-Press-Table/T26932
IMO, the price is right. And this works great IMO.
