Attaching wood legs to non-wood tabletop
Forum topic by BeginnerBowlBill posted 06-19-2017 05:48 PM 519 views 0 times favorited 11 replies Add to Favorites Watch
View BeginnerBowlBill's profile
BeginnerBowlBill
13 posts in 535 days
06-19-2017 05:48 PM
Hi Folks, I need your input. I’m making a pottery wheel and I’m trying to attach wood legs and skirt to a laminate tabletop (Corian.) Any ideas on the best way to do so? I can’t use wood screws in the laminate, and I don’t think it would be strong enough to put lag screws into the end wood of the legs (If I picked up the heavy unit by the table top it might pull out. The skirt is only 1 inch wide, but I can change to a 2×4 if needed. Any ideas would be greatly appreciated. Thanks!
11 replies so far
View jerryminer's profile
jerryminer
943 posts in 1560 days
#1 posted 06-19-2017 06:39 PM
I would make the base (legs and apron/skirt) like a table—separate from the top, and include either a full “sub-top”—like you would do in a kitchen counter situation—or a couple of “stretchers” across the top of the base, then use an adhesive caulk to attach the Corian to the base. (I did this to a rolling cart in my kitchen—20 years and holding)
Or, if you can live with visible fasteners, you could screw (or through-bolt) down through the Corian into the wood below .
View papadan's profile
papadan
3584 posts in 3487 days
#2 posted 06-19-2017 06:40 PM
I think I would try and epoxy some L brackets to the bottom of the corian. When the epoxy is cured I would screw the legs and aprons to the brackets.
papadan
#3 posted 06-19-2017 06:42 PM
Jerry types faster, he’s got a pretty good idea.
BeginnerBowlBill
#4 posted 06-19-2017 06:47 PM
I don’t mind bolts through the top or sides but I just don’t want it to crack the laminate. I don’t think glue would hold it. the heavy motor, pulleys, etc are under and if I lifted it with the top only it might come off. I will be moving it a lot. THanks
View builtinbkyn's profile
builtinbkyn
2633 posts in 1059 days
#5 posted 06-19-2017 07:02 PM
You can attach a plywood sub base to the Corian and then use any of the methods mentioned. It’s probably not a bad idea to use a sub base as it will strengthen the Corian and prevent the cracking you have concern about. Epoxy will work on both surfaces, to laminate them together. 3/4” ply is what I would use.
-- Bill, Yo!......in Brooklyn & Steel City :)
BeginnerBowlBill
#6 posted 06-19-2017 07:46 PM
That’s a great idea, thanks. But man I hate to make this thing heavier that it already is. Best idea yet though.
jerryminer
#7 posted 06-19-2017 08:13 PM
- BeginnerBowlBill
The solution to that: Don’t lift it by the top—lift it by the apron (goes for any table, really)
BeginnerBowlBill
#8 posted 06-19-2017 10:32 PM
With 5 kids, easier said than done. :)
View bondogaposis's profile
bondogaposis
4928 posts in 2469 days
#9 posted 06-19-2017 10:34 PM
+1 on jerryminer’s suggestion.
-- Bondo Gaposis
View bc4393's profile
bc4393
73 posts in 1261 days
#10 posted 06-20-2017 01:45 AM
builtinbkyn
#11 posted 06-20-2017 04:25 AM
That s a great idea, thanks. But man I hate to make this thing heavier that it already is. Best idea yet though.
- BeginnerBowlBill
You should scuff the to be bonded side of the Corian by sanding with a corse grit paper. You also might consider using a silicone based construction adhesive or even pure silicone. That is what’s used to mount countertops. The epoxy will also work, but it’s more expensive than a tube or two of construction adhesive. Use a shallow notched trowel to spread the adhesive. A 1/16”x1/16” should work well.
