Mitre splines grain
« back to Joinery forum
Forum topic by JoshNZ posted 06-19-2017 06:59 AM 577 views 0 times favorited 3 replies Add to Favorites Watch
View JoshNZ's profile
JoshNZ
94 posts in 942 days
06-19-2017 06:59 AM
Topic tags/keywords: mitre joint splines
I’ll save the explanation and share a photo…
The corners are obviously mitre joints. I have cut blind slots for splines to go inside them. I don’t have any boards as wide as the box is deep, so I can’t rip a single spline with the grain orientated across the joint, which would be ideal strengthwise, I think…
I could rip a board into splines to run along the joint but I wondered since it’s blind anyway, will I gain more strength from 2-3 splines beside each other, grain orientated across the joint?
3 replies so far
View HTown's profile
HTown
84 posts in 1058 days
#1 posted 06-19-2017 08:30 AM
Your work looks very good.
I don’t think it matters if it is one, two or more pieces to fill the spline. Like you mentioned, the grain orientation is most important.
View jdh122's profile
jdh122
969 posts in 2690 days
#2 posted 06-19-2017 10:33 AM
I don’t think it matters whether you use a single piece or 2-3 pieces as the spline, since the strength is in the length of the spline rather than its width.
-- Jeremy, in the Acadian forests
JoshNZ
#3 posted 06-19-2017 11:11 PM
I don t think it matters if it is one, two or more pieces to fill the spline. Like you mentioned, the grain orientation is most important.
- HTown
Thanks. And thanks, for both answers. Ripped a piece that would fit in the slot and cut it into little pieces to go across the joint. I think I’ll get away with just two.
