how to dry lumber that got wet
Forum topic by davecohn posted 895 days ago 1067 views 0 times favorited 4 replies Add to Favorites Watch
View davecohn's profile
davecohn
38 posts in 2234 days
895 days ago
today I had a flood in my basement and I have a couple hundred feet f s2s and s4s lumber, mahogany, maple, etc. that was in cold water for a few hours. What is the best way to dry it so it doesn’t twist and warp and will keep it useable.
thanks,
Dave
-- Dave from Buffalo Grove
View lilredweldingrod's profile
lilredweldingrod
2498 posts in 1275 days
#1 posted 895 days ago
Dave, I’m no expert, but I would stack it with stickers between each one and weight the top with concrete blocks for a few weeks, or until it tested in the proper range.
View John Ormsby's profile
John Ormsby
1235 posts in 1905 days
#2 posted 895 days ago
It would be best to take it into a garage or storage shed and sticker it. Your basement will have way too much moisture in it if you leave it there. I don’t think you want to have any mold forming down there. You might get some staining but it should be OK after you work it.
To sticker it properly, place stickers about every foot and try to start the stack at least 3” off the floor.
-- Oldworld, Fair Oaks, Ca
View SwedishIron's profile
SwedishIron
142 posts in 1809 days
#3 posted 895 days ago
Dave,
I would also recommend getting it out of your basement and for a few days or weeks keep let the wet lumber dry in a place with better ventilation.. basements are perfect environments for mold and mildew to grow on wet wood. I think as lilredweldingrod said, stacked, stickered and weighted down.. just a matter of time before it is useful again.
-- Scott, Colorado
View Pete_Jud's profile
Pete_Jud
407 posts in 1921 days
#4 posted 895 days ago
If your are insured, I would file a claim, and then sticker the wood outside covered with the weights, and get the check, and a year from now, start using that wood. The adjuster will just total it, not knowing that it has any salvage value, and I also assume you had some tools down there as well.
-- Life is to short to own an ugly boat.
