Will running a "bad board" through a planer, mess with a bearing?
Forum topic by newbiewoodworker posted 12-08-2010 12:40 AM 2168 views 0 times favorited 33 replies Add to Favorites Watch
View newbiewoodworker's profile
newbiewoodworker
668 posts in 2823 days
12-08-2010 12:40 AM
I contacted Porter Cable, over this planer issue, a stripped screw, and a squeeling cutterhead. They told me that I need to have these replaced at the factory service centre. They said its a bearing probably, causing the squeeling, and the screws need to be extracted. When I asked if it were covered under warranty, I recieved the snipety reply of “It is not a warranty issue when you run a bad board through the planer. Warranty covers factory defect. ”... well way to treat your customer folks… Last I checked bearings are your issue… since a bearing doesnt generally go bad within 6 months… Pardon my french, but these friggin people are obviously not the brightest…
Also, I would imagine the screws are by far, very high carbon, since I dont think I can damage my HF chisels as easy as I did that screw…
Oh, and lets not forget, they probably will want close to $100 to do this, between screw extraction, and the damn bearing…
If you guys say that it wont, mess the bearing up, and they still proceed to tell me its my problem… well, they better begin to like the better buisness buearu… they are like my attack hounds… and always bring back a piece of their ear… lol.. as I dont need the agriration…nor the cost…
I do have a local lead on an old, made in america, 12” Jointer, and a big planer… I just want to see what these puppys go for… lol… So I think, goodbye Black and Decker… :P Gotta love people getting rid of Iron Overflow… :)
-- "Ah, So your not really a newbie, but a I betterbie."
33 replies so far
13603 posts in 3337 days
#1 posted 12-08-2010 12:53 AM
buck up there newbie
i don’t know how many tools i’ve gone thru in 46 years
buy ‘em use ‘em break ‘em dump ‘em
if they get me to the next job
i get what i can afford and move on
waiting for perfect doesn’t matter to much
do the best you can
with what you have
work your way up
then you will really know
what to get
View rance's profile
rance
4258 posts in 3156 days
#2 posted 12-08-2010 01:35 AM
If I have a ‘bad’ board, I put it in time-out until it behaves, then run it through the planer. If, however, one got past me, then I expect the planer to ‘straighten it out’. Works EVERY time. Seriously, ask PC what kind of ‘bad board’ could possibly cause this. Warranty should cover a bearing unless you are using it commercially for hours a day. Sick-em BBB! But David is also right(after the warranty runs out of course). :)
View Sawkerf's profile
Sawkerf
1730 posts in 3064 days
#3 posted 12-08-2010 01:41 AM
I’ve read some of your posts and I thinking that;
a. You’re the unlucky receipient of a lot of really bad tools, or
b. Your expectations are far beyond what a tool manufacturer can possibly build – unless they have a NASA budget, or
c. You’re using the tools in ways the manufacturer never intended and getting ticked off when they have problems.
newbiewoodworker
#4 posted 12-08-2010 02:00 AM
Definately (a)....
Reason:
- How could I have caused a bandsaw’s tracking arm to snap? THis is a known weakness in that piece, for that brand of saw. More simply, its pot-metal…
-I use the planer in less a way, than most people. Granted, these tools are junk to begin with, they should atleast be working junk. I plane boards rarely. And when I do, I take roughly 1 turn of the wheel, each pass. There is no depth guage on this, so its all by feel, essentially. These tools technically are rated to take 1/8 of an inch, per pass, although it does wear the knives out. So I take between 1/16, and 1/8 off..l. so maybe 3/32nds.
So I think I can justify my statement, that I have just been the reciepiant of some really piece of s**t tools…. lol.. to put it bluntly. Now granted, the screw was partly my fault; After seeing it tightened down so much(I had to use a breaker bar to undo them), I probably over tightened them, using the breaker bar again..(believe me, now I cant get them off, w/o using one.. lol… But I didnt want to dodge flying knives… lol.. But I dont think I caused a bearing to kick it..
View Blakep's profile
Blakep
232 posts in 2798 days
#5 posted 12-08-2010 03:33 AM
Newbie, the bearing should probably be replaced under warranty but a word of advice on these benchtop or portable planers, I have a dewalt one and so far it has been a great planer but I usually take about 1/32 off per pass. Sometimes I will take a 1/16 and it does ok. I know they are rated for 1/8 but mine realistically want handle that much very well. I take 1/32 off and just make a few passes. If they fix the bearing under warranty then try cutting it down to about 1/32 per pass and I think it will help your machine last longer.
View Julian's profile
Julian
880 posts in 3521 days
#6 posted 12-08-2010 03:33 AM
I have abused my dewalt 735 planer daily for about 6 years now and I have yet to have any problems with it. I would say you have a defective part that SHOULD be under warranty.
-- Julian, Park Forest, IL
newbiewoodworker
#7 posted 12-08-2010 03:43 AM
Okay, thx guys. I was pretty certain that a bearing would be a defective part.. since it never did it before… And I know that Bearings are ususally rated for a long time, as long as they dont sit for 20 years, unused… I mean its pretty darn simple, some BBs in a ring, with a glob of grease… And they arent expensive.. but the labor would be… :(
View NormG's profile
NormG
6111 posts in 3000 days
#8 posted 12-08-2010 04:00 AM
I do not know what to say. Maybe contact customer service and ask to speak with a manager. Bearings are easy to replace. In regards to bad wood, the only time i have seen what i think you are describing is when someone put an end grain glue up through their planer.
-- Norman - I never never make a mistake, I just change the design.
View Ole's profile
Ole
67 posts in 3072 days
#9 posted 12-08-2010 04:03 AM
I know this isn’t very constructive, but what exactly is a “bad” board supposed to be?
newbiewoodworker
#10 posted 12-08-2010 04:08 AM
I certainly did no such thing! lol… I would have been freakin killed.. lol.. By the Planer Gods.. and the shrapnel…
Ole: My point exactly… I have never seen a bad board… she also went on to say, that knots cause bent knives? Well then if thats the case, mine should look like a Carrot ripple cutter…. Cause all wood has knots…
#11 posted 12-08-2010 04:10 AM
whenever i hit a ‘bad board’
tapered or to curved
i back the cutters off
before it gets worse
then come down slowly
flipping the board over
and doing the other side to
till it slides better
View Dark_Lightning's profile
Dark_Lightning
3159 posts in 3105 days
#12 posted 12-08-2010 04:12 AM
Ole, from the sounds of it, it is iron wood, or something. ;) I guess I believe that the customer service rep actually said “bad board”, since that’s the way it’s reported, but that sounds lame. Realistically, I’ve shaved some mighty thicknesses off boards with my PC tabletop planer and didn’t zorch a bearing. Sounds like a defect to me.
-- Random Orbital Nailer
View JasonWagner's profile
JasonWagner
527 posts in 3176 days
#13 posted 12-08-2010 04:27 AM
+1 to only taking 1/32” to 1/16” off on a lunch box planer. As long as they don’t blame the bearings on the stripped screw (if you did it) I would be pretty adamant about it being covered under warranty. If the machine looks clean except for the bearing you’re good, if it’s beat up you never know what they’ll say. It’s like fighting…don’t leave it to the judges.
-- some day I hope to have enough clamps to need a clamp cart!
newbiewoodworker
#14 posted 12-08-2010 04:34 AM
Its pretty dam emaculate… I wax the darn thing weekly… I open the dust hood, and clean that, bi-weekly… I vacume it… after most uses…
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3102 days
#15 posted 12-08-2010 05:20 AM
A bad board….....hhmmmmmmm…..Is that a Naughty board or a Knotty board? What in the world could this teenager have been thinking? Run a board through a planer? Aren’t you aware that this might possibly get dust inside the machine? For shame, for shame. These PC planers are just to look at and wax. They must be dusted daily! Why your shop teacher should have explained this in great detail. Now you have to sue him for the repairs.
Well, it sounds good to Porter Cable. Maybe we ought to Scotch hobble them.
showing 1 through 15 of 33 replies
