Delta TS 36-725 Help
Forum topic by ShemATC posted 06-16-2017 11:52 PM 637 views 0 times favorited 2 replies Add to Favorites Watch
View ShemATC's profile
ShemATC
10 posts in 1049 days
06-16-2017 11:52 PM
I’ve had my 36-725 for a short time now, but have run into some issues with the wheel.
The wheel lever for the unit seems to have developed a problem that I can’t seem to figure out. From what I recall when I put it together, it seemed to work great. I didn’t move it very far so I don’t know if this happened from the beginning or not.
-Is the wheel lever supposed to stay locked down somehow (i.e. you can lift the saw up on the wheel and it will stay there)? I seem to remember it being able to do that when I first assembled it, but now it won’t.
-I can only wheel the saw in 1 direction, towards the set straight wheels. If I try to reverse it the swivel caster can not clear where it attaches and gets stuck. It’s rather awkward to try to move in this fashion.
Could someone who has the saw possibly post a close up picture of the wheel/pedal (hopefully in both up and down positions) so I can see if something is off? Thanks.
2 replies so far
View hotbyte's profile
hotbyte
991 posts in 3216 days
#1 posted 06-17-2017 12:12 AM
Not sure what would cause your issue, but the lever should lock in position to make saw mobile.
View LucasAZ's profile
LucasAZ
9 posts in 650 days
#2 posted 06-17-2017 06:09 PM
Yes, when you push down on the foot lever the wheel should be locked in the down position. I can also swivel the saw in any direction with the wheel down, so it sounds like you have a problem. Here are some pictures I took of mine:
Here is the wheel in the down position
Here is the wheel in the up position
And finally here is one in the middle of the motion showing the “cam” on the foot pedal
I hope this helps!
Lucas
