Table saw wont cut a "perfect" square?
Forum topic by jonnybrophy posted 06-16-2017 04:26 PM 2067 views 0 times favorited 18 replies Add to Favorites Watch
View jonnybrophy's profile
jonnybrophy
160 posts in 853 days
06-16-2017 04:26 PM
Topic tags/keywords: question tablesaw miter saw
Hey guys, following the purchase of my current contractors saw, ive been trying to tune it up to the best of my abilities.
Fence and blade are parallel to the miter slots, and everything seems good, however,
no matter what i do, I cant seem to cut a square piece of wood.
This happened with my old table saw too, what am i doing wrong? I cut one side, rotate, cut , rotate, cut etc
but it never turns out square( 4 90 degree angles)
P.S. I am using the delta sliding table attachment, and ive been trying to tune that as well. I used an anle finder between he front of the blade and the sliding table, and also the back of the blade and the sliding table. Both check out at 90 degrees.
Please help, thank you in advance
-- "If she dont find ya handsome, she better find ya handy"
18 replies so far
View jmartel's profile
jmartel
8292 posts in 2391 days
#1 posted 06-16-2017 04:29 PM
Small errors add up. Remember that you have 4x the error the way you are cutting.
View firefighterontheside's profile (online now)
19635 posts in 2098 days
#2 posted 06-16-2017 04:32 PM
What he said. Try cutting a piece that is the width you want with the table saw fence. Then cut it to length(same as the width)
jonnybrophy
#3 posted 06-16-2017 04:55 PM
Update:
Upon further inspection
three of the four corners are “90” degrees but one is at 92 degrees. I think i might be off by .25 of a degree. ( if my math is alright)
Is there anyway to reliably get 90 degrees dead on with my sliding saw (Delta 34-555)?
Thank you for the previous responses
#4 posted 06-16-2017 05:19 PM
If that sliding table has calibration adjustments, look up the 5 cut method for squaring a crosscut sled and adapt it for your purpose.
View Ruewood's profile
Ruewood
6 posts in 587 days
#5 posted 06-16-2017 06:34 PM
Well, unfortunately the smaller contractors table saws are not as precise as a larger cabinet saw, not discounting a contractor saw here. I would make sure your measuring devices (squares, dial indicators, etc) are accurate, when measuring off of the blade make sure youre not measuring off of the teeth but the face of the blade. Hope of some help
View Loren's profile
10477 posts in 3889 days
#6 posted 06-16-2017 06:39 PM
The 5-cut method will give you a waste
strip that tells you exactly how far off
you are. I haven’t done it in awhile so
I don’t remember for sure but I think if
the waste strip from the 5th cut comes
out with a 1/16” taper that means your
sliding table is off by 1/64”.
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#7 posted 06-16-2017 07:19 PM
Look up William Ngs crosscut sled build video. He explains everything and how to do it precisely.
jonnybrophy
#8 posted 06-16-2017 07:23 PM
Hello everyone, I am very sorry and now i feel like a dork, but….
Earlier this morning when i trying to adjust my sliding attachment to the right height, i accidentally knocked into the motor which must’ve upset the trunnions and moved the blade out of square.
I just found this out, and put it back in place.
Now i am much closer to a perfect square, however i am still off by a noticeable amount. I tried adjusting the sliding table adjustments but its still off and i backed off the positive stop for 90 degrees all the way back. I am thinking im going to have to mess with how it is attached to the saw.
Thank you everyone for your comments
View avsmusic1's profile
avsmusic1
301 posts in 927 days
#9 posted 06-16-2017 07:44 PM
+1
- TheFridge
View BlasterStumps's profile (online now)
BlasterStumps
1081 posts in 681 days
#10 posted 06-16-2017 10:40 PM
Thanks for posting this info. I plan to watch it a couple times at least. Very good.
Mike
- TheFridge
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Holbs's profile
Holbs
2042 posts in 2271 days
#11 posted 06-17-2017 12:10 AM
I will be doing the 5 cut method shortly myself. In the mean time… how are you measuring your parallel’ism from miter slots to blade, from miter slots to fence? Dial calipers to give that ultra fine measurements in the thousandth? If everything is aligned to 0.000-0.001, I dont see how you could be off 92 degrees on your 4th cut.
jonnybrophy
#12 posted 06-17-2017 12:17 AM
Im using a combination square -_-
I wish i had a dial indicator, but no money atm…
Holbs
#13 posted 06-17-2017 12:18 AM
local auctions. I have…6 dial indicators for $5 from a single lot. And I think Harbor Freight has the magnetic base ones for $20
Holbs
#14 posted 06-17-2017 12:21 AM
a word of note: if you have other machines as well as your table saw that need aligned, dial calipers are the true way to go. invest in 1 even if china one to hold you over.
jonnybrophy
#15 posted 06-17-2017 12:23 AM
Thanks Holbs,
One day I will own one of those mitutoyo calipers, one day…..
