Cutting board question
Forum topic by PeteMoss posted 897 days ago 1187 views 0 times favorited 13 replies Add to Favorites Watch
View PeteMoss's profile
PeteMoss
186 posts in 1639 days
897 days ago
I understand the reasoning behind end grain cutting boards, what with the not severing any fibers and it being gentler to your knife edges and all that. Artistically I can also see where people can do some really amazing things putting them together with different woods and shapes and whatnot.
My question is this. For someone who is just wanting to put a attractive piece of wood in the kitchen to cut on, it there anything really wrong with an edge grain board? Again I understand the theory, but would I, as a typical homeowner, cause enough wear to either the board or the knife in real life for it to matter? I’m asking because I’m thinking about taking a nice looking piece of wood and using it, not even cutting it into strips, just sizing it, sanding it, and putting some mineral oil on it, and letting it be a pretty piece of wood. Any thoughts on this are much appreciated. Thanks.
-- "Never measure......cut as many times as necessary." - PeteMoss
13 replies so far
View mstenner's profile
mstenner
56 posts in 1323 days
#1 posted 897 days ago
Basically, that will work fine. You sharpen your knives slightly more often… no big deal. The biggest “problem” I see with that approach is that the wood will move substantially over time. You’ll probably end up with something that cups quite a bit, and due to the exciting life of a cutting board, I wouldn’t expect to just be able to resurface it and have it remain stable after that.
-- -Michael
Beginningwoodworker
13225 posts in 1842 days
#2 posted 897 days ago
You use the end grain for a cutting board because its more durable.
-- CJIII Future cabinetmaker
View grizzman's profile
grizzman
5384 posts in 1472 days
#3 posted 897 days ago
hey Pete, it will work just fine, but as mentioned above, it could eventually cup and then it would basically be done..but if you keep if oiled really well , you will prevent the cupping for some time..and if all else fails…make a new one that is glued up and a bit thicker and you will have another cutting board…if you ever come this way towards Montgomery…stop on in…grizzman
-- GRIZZMAN ...[''''']
View PurpLev's profile
PurpLev
7749 posts in 1817 days
#4 posted 897 days ago
it would work just as well.
end grain cutting board can cup just as much as edge grain cutting boards! I made both, and the END grain is the only one that cupped on me – in a bad way.
The only real advantage in end grain is the fact that you don’t actually cut the fibers down which helps both visually, and the longevity of the board.
View rowdy's profile
rowdy
370 posts in 1611 days
#5 posted 897 days ago
Use only one side for cutting and keep the other side clean for display if you want to continue to look at a nice looking piece of wood, as you described it.
-- Rowdy in Kechi, Kansas
View Lee Barker's profile
Lee Barker
1887 posts in 1019 days
#6 posted 897 days ago
Given your choice board, you could rip it into pieces approx 2 1/2 inches wide, say, and invert the odd ones and glue it back together to minimize cupping.
Of course, if you had a few alternately-colored strips to put into those glue joints…hoo hah!
And flat grain will be fine. Worst case scenario if it gets a little ratty, bring it into the shop and ROS it with some 80 grit to degrease it, run it through the planer and it’s like new.
PeteMoss
#7 posted 897 days ago
Hey thanks everyone. Sounds like I’m just gonna make one, cut with it, and refinish or make a new one as necessary.
View Brad_Nailor's profile
Brad_Nailor
2449 posts in 2126 days
#8 posted 897 days ago
I love edge grain boards, as much as end grains. Rip different widths of complimentary woods and make mirror image patterns. I bought a thin strip ripping jig , and I slice off real thin pieces of different woods, and make pin stripes. I prefer edge grain to face grain..i think it holds up to knife abuse better than face gran boards, but not as nice as end grain.
View tbone's profile
tbone
252 posts in 1853 days
#9 posted 896 days ago
Cutting Boards 101—class is in session.
As we all know, there are 2 types—end-grain and edge or face grain.
“End grain” cutting boards are actually ‘chopping blocks or butcher blocks’—primarily used by butchers for cutting meats, as well as other professionals where bacteria control is paramount.
“Edge of face grain” cutting boards are usually used as cheese boards, bread boards, and vegetable boards. The grain can be advantageous here because they usually double as serving boards.
In the next class, we’ll be discussing why Han Solo doesn’t disintegrate when the Millenium Falcon hits hyperspace.
-- Kinky Friedman on gay marriage: "They should have the right to be just as miserable as the rest of us."
View MrsN's profile
MrsN
917 posts in 1695 days
#10 posted 896 days ago
I have a really simple edge grain cutting board that I use at home. Just maple and walnut stripes about 1 1/2” wide. I don’t like to cook all that much, so it doesn’t get used much. I almost wish I could wear it out more so I have an excuse to make a cool one.
-- ----- www.KNWoodworking.com ----- --
View jm82435's profile
jm82435
1217 posts in 1911 days
#11 posted 896 days ago
I have one I made in shop class probably 30 years ago, it is still going strong. About every 10 years I have run it through the planer to clean it up a little, then re-oil and it is as good as new.
-- A thing of beauty is a joy forever...
View DavidH's profile
DavidH
488 posts in 1912 days
#12 posted 890 days ago
edge grain will work fine. woodsmith shop did a show on some edge grain cutting boards with splines on either end which should help prevent cupping.
they have the plans as a free download:” http://www.woodsmithshop.com/download/208/cuttingboards.pdf":http://www.woodsmithshop.com/download/208/cuttingboards.pdf
-- David - Houston, Texas. (http://www.justsquareenough.com/)
View jerryw's profile
jerryw
158 posts in 2085 days
#13 posted 890 days ago
if you cut with the grain your board will not get cut up so bad. don’t cut across the grain it cuts the fibers in the wood. oh, throw away searated knifes.
-- jerryw-wva.
