Delta Double Duty Lathe
« back to Woodturning forum
Forum topic by Tiggu posted 06-15-2017 04:54 PM 1775 views 0 times favorited 11 replies Add to Favorites Watch
View Tiggu's profile
Tiggu
15 posts in 686 days
06-15-2017 04:54 PM
Topic tags/keywords: lathe wood turning
I found a Delta Double Duty lathe (“works perfect”) on Craigslist for $120. I’m new to wood turning. Would this be worth buying?
11 replies so far
View Woodknack's profile
Woodknack
12430 posts in 2581 days
#1 posted 06-15-2017 05:46 PM
View Wildwood's profile
Wildwood
2473 posts in 2335 days
#2 posted 06-15-2017 07:37 PM
Seen one like this of E-Bay for $100 with free shipping!
http://www.vintagemachinery.org/photoindex/detail.aspx?id=2399
Not sure if same one you are talking about but depends upon what you want to do with it. If just starting out and want to do mostly spindle turning should be okay.
-- Bill
Woodknack
#3 posted 06-15-2017 08:01 PM
- Wildwood
If you mean this one, it’s free local pickup.
Woodknack
#4 posted 06-15-2017 08:13 PM
The 930 is rather robust and can easily handle risers to allow bowl turning. It has tapered roller bearings that run in an oil bath. it’s actually one of the better designed Delta lathe IMO.
Tiggu
#5 posted 06-15-2017 11:47 PM
Thank you for your input and the info.
View MrUnix's profile
MrUnix
7046 posts in 2399 days
#6 posted 06-16-2017 12:01 AM
There was more than one “Double Duty” lathe made by Delta… I can think of at least two – the 930 11” lathe that Rick mentions and the 955 which was an 8” lathe:
I seem to remember some others, but it’s fuzzy :) They used the “Double Duty” and “Triple Duty” names on a few of their machines back in the late 30’s/early 40’s. I believe they disappeared sometime around when they sold to Rockwell (ie: they were used when Delta was named the “Delta Specialty Company”).
View Gentile's profile
Gentile
314 posts in 2019 days
#7 posted 06-16-2017 02:29 AM
This one I picked up at a yard sale for $100.00.
It was fun to refurbish.
I figured it would be a good one to learn on before I bought a bigger one some day…
-- "I cut it twice and it's still too short"
Woodknack
#8 posted 06-16-2017 02:38 AM
You can put spacers under the head and tail stocks for more swing.
Woodknack
#9 posted 06-17-2017 09:17 PM
Did you buy it?
Tiggu
#10 posted 06-17-2017 10:16 PM
I waited too long but will keep an eye out for another one.
MrUnix
#11 posted 06-17-2017 10:20 PM
- Tiggu
Yet another victim of OWWM rule #5 :)
