Bolt Lubrication
Forum topic by BentheViking posted 06-15-2017 01:37 AM 1469 views 0 times favorited 30 replies Add to Favorites Watch
View BentheViking's profile
BentheViking
1782 posts in 2804 days
06-15-2017 01:37 AM
Topic tags/keywords: miter saw jointer
Hopefully someone on here can give me some good insight.
Right now both my miter saw and jointer are out of commission. My jointer was used and I have never taken the bolts out, but am looking to change the blades. Two of them came out ok, but the other 6 are stuck in their. I’m at the point where I know I am going to cut/drill them out and get new bolts (new ones already on order). At the same time as I decided to finally figure out that problem, I decided to clean my saw blade and broke off the arbor bolt trying to get it free. I was able to drill out the broken part (the heat loosened it enough so it slid out – hoping for similar results on the jointer) and a new arbor bolt is already on order.
My question is how to prevent this in the future. 7 bolts for the two tools cost me nearly $40. Do you lubricate the threads before installing them? If so with what? Do you slightly loosen and retighten the bolts periodically? Every time you use the machine? I’ve been trying to find the best tips online for hours and can’t find anything so give a brother some help – I need to get my shop back up and running!
-- It's made of wood. Real sturdy.--Chubbs Peterson
30 replies so far
View Richard Lee's profile
Richard Lee
213 posts in 1015 days
#1 posted 06-15-2017 01:52 AM
Have you ever had them off before?
The only problems Ive had is from used machinery that has never been apart or a Jointer that has sat for years in a barn.
Carefull with grease because it can affect torque values. I just use some Penetrating oil on bolts and torque as usual.
View jonah's profile
jonah
1972 posts in 3538 days
#2 posted 06-15-2017 02:33 AM
Put some anti-seize on them. You can get it online or at an auto parts/hardware store.
Seized bolts you can try putting a torch to, but there’s no guarantees, and if there’s any kind of seal or gasket or anything attached to the other side of that metal part you’ll almost certainly melt it.
View Rayne's profile
Rayne
1124 posts in 1779 days
#3 posted 06-15-2017 02:48 AM
Has anyone ever tried WD-40 on these? I’ve had some success on screws and bolts in the past; like long time ago past.
View Bill White's profile
Bill White
5149 posts in 4200 days
#4 posted 06-15-2017 12:12 PM
Permatex anti-seize compound. Buy a tube and be set for life. That stuff lasts forever.
Bill
-- bill@magraphics.us
View Markmh1's profile
Markmh1
93 posts in 683 days
#5 posted 06-15-2017 01:21 PM
I’m with Jonah on the anti seize.
The brand I’m most familiar with is made by Loc Tite. This stuff is great when you need to get bolts out/stuff apart.
Mark
View John's profile
John
245 posts in 1821 days
#6 posted 06-15-2017 01:35 PM
PB Blaster or Kroil on seized bolts. Spray it, wait a while, then try it. Repeat as necessary, usually works for me for everything but the most stubborn ones.
As far as preventing it +1 on anti seize.
-- I measured once, cut twice, and its still too short...
View waho6o9's profile
waho6o9
8539 posts in 2817 days
#7 posted 06-15-2017 01:49 PM
Copper grease.
View GR8HUNTER's profile
GR8HUNTER
5396 posts in 952 days
#8 posted 06-15-2017 01:51 PM
A LITTLE DAB anti – seize goes a long way …HAVE A RAG HANDY LOL :<))
View bigblockyeti's profile (online now)
bigblockyeti
5318 posts in 1960 days
#9 posted 06-15-2017 02:02 PM
I would stay away from anti-seize unless your machines spend considerable time in a humid environment. I would instead use paste wax applied liberally then buff away as much as possible before reassembly. This will prevent having grease slung onto your work piece and it won’t attract dust like cease will.
View diverlloyd's profile
diverlloyd
3288 posts in 2097 days
#10 posted 06-15-2017 02:23 PM
I have had luck with heating up a bolt that is seized and while it’s hot touch it with some waxit will wick down the threads.Bees or a old candle works. I had a older guy show me that and I thought it was bs but it works also automatic transmission fluid will help loosen up stuck bolts. A drop or two and then let it sit over night and see if it worked if not repeat the process.
View HokieKen's profile
HokieKen
7589 posts in 1378 days
#11 posted 06-15-2017 02:42 PM
I usually rub the threads across a block of paraffin wax before putting a steel bolt into steel or cast iron. It’s a pretty common machinists trick. Just a thin layer forms a barrier layer against corrosion without too much lubrication. Old timers used a bar of hand soap but I don’t know if it works as well…
Edit: FWIW, the most common cause of stuck bolts is that some folks think you need to get it as tight as you can. Don’t go “gorilla” on your fasteners!
-- Kenny, SW VA, Go Hokies!!!
View Tony1212's profile
Tony1212
267 posts in 1974 days
#12 posted 06-15-2017 03:45 PM
I’ve also found that impact drivers (look like drills and are usually sold in a set with a drill) work well in removing stuck fasteners. Used with a bit of penetrating oil, I was able to easily remove those stupid screws holding the rotors the hubs on my wife’s car. Those are usually a PITA to get out.
-- Tony, SW Chicago Suburbs
jonah
#13 posted 06-15-2017 05:48 PM
I would stay away from anti-seize unless your machines spend considerable time in a humid environment. I would instead use paste wax applied liberally then buff away as much as possible before reassembly. This will prevent having grease slung onto your work piece and it won t attract dust like cease will.
- bigblockyeti
You don’t need much anti seize for it to work. Just a small dab will do it.
BentheViking
#14 posted 06-16-2017 01:50 AM
Thanks everyone. At this point I think I am far more concerned with making sure it doesn’t happen again as opposed to getting the current set of bolts unstuck (I know I may be pulling the cart before the horse). It seems like anti seize might be the best way to go.
View MrUnix's profile
MrUnix
7107 posts in 2439 days
#15 posted 06-16-2017 02:02 AM
I usually rub the threads across a block of paraffin wax before putting a steel bolt into steel or cast iron. It s a pretty common machinists trick. Just a thin layer forms a barrier layer against corrosion without too much lubrication. Old timers used a bar of hand soap but I don t know if it works as well…
- HokieKen
+1 on paraffin. And to make it even easier, I keep a mason jar of paraffin dissolved in mineral spirits, with a little wire basket, which make it easy to dunk nuts, bolts, washers, screws, etc…
Not only does it lubricate, but it helps prevent corrosion and gets into places you can’t with just a bar of wax.
Once the mineral spirits flash off, you are left with a nice thin coat of wax everywhere. BTW: Paste wax is basically paraffin in naptha :)
showing 1 through 15 of 30 replies
