Dealing with alligator marks on lacquer finish
Forum topic by Rich posted 06-15-2017 01:31 AM 1204 views 0 times favorited 2 replies Add to Favorites Watch
View Rich's profile
Rich
3996 posts in 826 days
06-15-2017 01:31 AM
Topic tags/keywords: question
I made the mistake of spraying some boxes with lacquer too far into the heat of the day. The surface developed almost imperceptible alligator marks (crazing) that you need to magnify to see, but they do affect the quality of the surface in appearance and feel.
I was thinking of trying to amalgamate the surface by spraying lacquer thinner. Any tips, techniques or other advice anyone can give me?
2 replies so far
View TungOil's profile
TungOil
1080 posts in 731 days
#1 posted 06-15-2017 01:50 AM
Rich
If you are spraying nitrocellulose lacquer, the next coats should melt into the previous ones. If the crazing is minor, you might try sanding it and reshooting. If it’s hot where you are adding some retarder might help as well (not thinner). if you are using rattle cans, you’ll need to wait for better weather.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Rich's profile
Rich
#2 posted 06-15-2017 04:25 AM
I’m glad you asked that Tung. Actually, one was done with big box nitrocellulose lacquer, and the other was done using pre-cat lacquer. They both have similar issues, but with a slightly different overall effect.
I’ll probably wind up sanding and re-coating, but as I try to learn, I wanted to try some different fixes first.
Thanks for the feedback.
