Hooking up 2 dust collectors: series, parallel or waste of time?
Forum topic by Sark posted 06-14-2017 03:02 PM 1775 views 0 times favorited 5 replies Add to Favorites Watch
View Sark's profile
Sark
74 posts in 479 days
06-14-2017 03:02 PM
Topic tags/keywords: dust dust collector dust collection ducting
As a result of a quick Craigslist purchase, I now own 2 dust collectors: 2 HP grizzly and 1 HP UFO. I’m getting ready to put in a decent dust collection system. There are 3 ways to use these 2 collectors:
1. Series or tandem: where the 1 hp feeds into the 2 hp (or Vice versa). This theoretically would increase static pressure.
2. Parallel: Both dust collectors connect into a single larger duct. This theoretically would increase the CFM of the system.
3. Don’t use: Since the dust collectors are mismatched, the small one might impede the flow of the large one, reducing any possible advantage. In parallel, the overall CFM would increase. It would be a pain to do the extra duct work in either case, and cost more money for fittings.
Why do I want to do this? Trying to make best use of equipment that I already own. In my old shop, we used the ClearVue cyclone with 6” ducting everywhere. But now I’m back to the old garage, and dust collection is the highest priority for shop improvement.
Thanks for your thoughts.
5 replies so far
View papadan's profile
papadan
3584 posts in 3487 days
#1 posted 06-14-2017 03:05 PM
Use the grizzly and just sell the other one and use the money to buy duct for your system.
5069 posts in 2612 days
#2 posted 06-14-2017 03:49 PM
- papadan
^^^^^ Yep. This question comes up about once a year (although it’s usually a matched pair of HF DCs). But I’ve yet to go back and see someone explain what a great idea is was. I think Stumpy Nubs did that (with the HF units), you might check his stuff and see what happened, but I don’t recall him saying it was a great idea either (I could be wrong).
View jonah's profile
jonah
1837 posts in 3418 days
#3 posted 06-14-2017 04:06 PM
1) No, it won’t work.
2) No, it won’t work.
3) Yes.
You are always, always better off with one big motor and one big impeller.
View TungOil's profile
TungOil
1006 posts in 614 days
#4 posted 06-14-2017 04:29 PM
Don’t try to mix two DCs into the same system. Either use the larger one, or if you have room you could effectively create two systems by collecting some tools that are close together into one DC then the rest into the other DC. You might save on some pipe but it will cost you in floor space.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Holbs's profile
Holbs
1930 posts in 2148 days
#5 posted 06-14-2017 05:41 PM
I say keep the #2 dust collector which is the…1 HP UFO. Handy for mobility. I have a 3HP Grizzly that is stationary… and I just picked up a 1HP Delta I plan to use on a cart…think of a super shop vac. Or can be used on a downdraft table… or…. finishing ventilation… or to tackle a machine that is 20’ or further away from your main 2HP dust collector. Can use the #2 DC for lots of good uses. Granted, I paid $10 for the 1HP Delta though.
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
