Delta 62-044 Blade not parallel to miter slot
Forum topic by Mars72 posted 12-05-2010 04:40 AM 5684 views 0 times favorited 12 replies Add to Favorites Watch
View Mars72's profile
Mars72
33 posts in 3252 days
12-05-2010 04:40 AM
Topic tags/keywords: tablesaw blade alignment parallel trunnion question
I purchased this saw used a few months ago. I have had trouble getting it setup correctly. The main problem is the blade is not parallel to the miter slots. It is off by 1/8”. So, I loosened the back two and one of the front trunnion bolts and tried to bump it over with piece of wood and a mallet. It does not move. It is like it is over as far as it will go already. Not sure what to do.
-- I usually try the hard way 2 or 3 times before finding the easy way.
12 replies so far
View Verna's profile
Verna
202 posts in 2773 days
#1 posted 12-05-2010 05:10 AM
Mars:
I did a Google search and found this comment on the Internet:
“The number “62-044” refers to the electric motor. The table saw model number is most likely located on the right-hand side of the saw. In my case it is “36-472.” Plug it into the manual search on the Delta-Porter Cable-Dewalt site and up comes the manual for the saw.”
www.deltaportercable.com is the official website for the Delta tools. Under “Service/Support”, there is a section for owner’s manuals. Hopefully you can find the manual and instructions on how to adjust your table saw.
-- Verna -- Indianapolis, IN
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3712 days
#2 posted 12-05-2010 05:50 AM
If the front won’t move can you move the back in the opposite direction?
Mars72
#3 posted 12-05-2010 06:08 AM
I have the manual. It just says that it was Factory Set… Mark, I took out a bolt in each corner of the trunnion and looked at it with a mirror. It looks like the front and back are as far as they can go in opposite directions.
Mars72
#4 posted 12-05-2010 06:10 AM
I meant in opposite Corners. :-)
Mark Shymanski
#5 posted 12-05-2010 06:20 AM
Hmmm, could you not knock them in toward the center and sort of split the difference on the mis-alignment. I think I can visualize what the problem is I just can’t explain what I mean to help you resolve it…I’m sitting here jesturing with my hands trying to clarify what I mean knowing quite well you can’t see me LOL!
Mars72
#6 posted 12-05-2010 06:35 AM
quick drawing… Not to scale and greatly exaggerated.
Mark Shymanski
#7 posted 12-05-2010 07:34 AM
I’ll try this again as my computer ate my last response :-)
As I see it you need to knock the top (of your drawing) to the left and the bottom to the right to center the angled line (the saw blade?), that is to make it more vertical to match the center line of the drawing. If that doesn’t work could you drop the trunion off (or lift the table off the trunion) to see if there is something (dust, gunk, chunks of wood etc.) wedging the trunion so it can’t move? I was going to suggest notching out the bolt holes, but that would weaken the casting and I can’t really believe that Delta would engineer a saw that could not be adjusted. This is the sort of thing I would love to be able to come over and give you a hand with. It has to have a solution.
View crank49's profile
crank49
4030 posts in 2970 days
#8 posted 12-05-2010 10:21 AM
When you have used up all the explanations, the only thing left has to be the solution.
You said the front and rear trunnion mounts are as far as they can go in opposite directions.
I will suggest the blade being about 1/8” out of parallel would be as far out of alignment as possible.
Try shifting the assembly back to the center and see if the blade alignment gets worse or better.
If it gets better, I think you see where this is headed.
Mars72
#9 posted 12-05-2010 05:11 PM
Arbor looks fine. Will try moving other direction.
Mars72
#10 posted 12-05-2010 08:02 PM
I loosened the front left too. Just enough.
View reggiek's profile
reggiek
2240 posts in 3270 days
#11 posted 12-05-2010 08:57 PM
You may try shimming the trunnion also (either at the mount or on the bolts).....I had an old job saw where I ground a washer at an angle to give just a tiny bit of space to a saw motor. I am sure there are other materials that would work the same….but my idea came to me after the saw had kicked back a piece of 2X4 I was ripping for the millionth time…..and I was tired of playing with the fence….....it worked until the day I got rid of the saw….and it is still working as far as I know.
10401 posts in 3647 days
#12 posted 12-05-2010 11:07 PM
Sometimes saws are defective. The trunnions usually have elongated
holes where they attach to the table. It may be necessary to disassemble
the saw and enlarge the holes so the trunnions can be adjusted to
the correct position.
Saws that come out of the factory with this manufacturing defect
are not that uncommon.
