Sanding "Dimples" - Help needed
Forum topic by ChunkyC posted 12-05-2010 04:18 AM 1497 views 0 times favorited 9 replies Add to Favorites Watch
View ChunkyC's profile
ChunkyC
856 posts in 3158 days
12-05-2010 04:18 AM
I made me a set of dominoes today and the dimples need a little attention. Anyone have any tips or tricks on sanding dimples? This one has me stumped.
The dimples where made using a 3/16 twist drill bit.
Thanks,
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
9 replies so far
View psh's profile
psh
79 posts in 2899 days
#1 posted 12-05-2010 04:33 AM
Dremel?
-- Peter, Central VA
View AaronK's profile
AaronK
1501 posts in 3368 days
#2 posted 12-05-2010 04:36 AM
sandflex blocks might work. you need something conformal that can get right in there. You might think up something that attaches to the end of a spindle so that you can attach it to your drill press and make the work semi automated.
View rance's profile
rance
4256 posts in 3064 days
#3 posted 12-05-2010 04:38 AM
Round nose ball mill for your dremel or one from MCLS made for a milling machine(but used in your drill press). If all else fails, paint them black.
Sometimes you have to MAKE a tool to do a job. Next time you drill those holes you may try making a D bit to drill them out. They’ll end up as round bottom holes, which you don’t get with a twist bit.
View KnickKnack's profile
KnickKnack
1088 posts in 3470 days
#4 posted 12-05-2010 09:28 AM
I’ve had success by wrapping a piece of sandpaper around a drill bit – probably a size smaller than the hole in your case – and elastic banding it in place. To get the bottoms done too you’ll need it to project a little beyond the end, but then it “works itself” into the hole. You need to wind it the right way around, and it’s best if possible to use a variable speed drill and go slowly.
Might work.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View davcefai's profile
davcefai
37 posts in 3301 days
#5 posted 12-05-2010 02:17 PM
If all else fails you could try filling the holes with coloured epoxy. Wipe off as much excess as you can and then use a card scraper when the resin has set but is not yet at its hardest.
-- David
View poopiekat's profile
poopiekat
4325 posts in 3638 days
#6 posted 12-05-2010 07:23 PM
On a side note, I got lots of complaints about my store-bought dominos…the ‘twelves’ version, because the holes were all painted black. I tried an artist’s brush, q-tips, nothing would work….until I used the hypodermic needle filler to an inkjet cartridge re-filler kit. Just sucked up assorted acrylic paints, and filled the holes on all the 7 and up dots with their respective colors with it! Easy!
View Vicki's profile
Vicki
1090 posts in 3248 days
#7 posted 12-05-2010 07:27 PM
ChunkyC
#8 posted 12-05-2010 09:21 PM
Vicki: Thanks for the tip! That may just do it.
I’m not going to paint or fill the holes. I use maple vernier over walnut so that I didn’t have to paint the dimples. The problem is the substrate from the PSA vernier. The adhesive “sheet” on the back of the vernier doesn’t drill well and leaves a little behind. The dimples need to be sanded a little to remove the adhesive “hair” that was left behind.
ChunkyC
#9 posted 12-06-2010 03:06 AM
Thanks for the tips. I had to go to town this afternoon so I stopped at the hardware store. I purchased a Dremel cutter, No. 192, that worked quite well. It’s the one that looks like a ball on the end of the shaft. It really cleaned up the dimples quite nicely.
