Cleaning up auger bits
« back to Hand Tools forum
Forum topic by BenDupre posted 06-13-2017 07:09 PM 708 views 0 times favorited 12 replies Add to Favorites Watch
View BenDupre's profile
BenDupre
648 posts in 510 days
06-13-2017 07:09 PM
Topic tags/keywords: auger bits rust cleaning
Picked up an old set of Stanley Russel Jennings augers on flea bay. They are in good shape with a little rusty spots. What is the most painless way to shine these up?
Thanks!
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
12 replies so far
View Bill White's profile
Bill White
4947 posts in 3982 days
#1 posted 06-13-2017 07:37 PM
There are some who would use a soft or brass wheel on the buffer. I prefer to use a stupid simple piece of cotton sash cord with valve grinding compound. Kinda act as if you’re shining shoes as the motion within the lands of the bits.
Sharpening is a different issue. Lots of time and good files.
Bill
-- bill@magraphics.us
View UpstateNYdude's profile
UpstateNYdude
917 posts in 2005 days
#2 posted 06-13-2017 07:39 PM
Soft brass wheel to get rid of the rust and dirt and then a buffing wheel or some metal polish.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View Tim's profile
Tim
3812 posts in 1984 days
#3 posted 06-13-2017 08:11 PM
The threads on the lead screw are relatively delicate, so anything you would need to use a brass brush on isn’t going to be easy to clean up to great shape. Here are the best things to do to auger bits:
1. Remove the rust. If you they are pitted and the lead screw is significantly rusty, again they won’t be easy to clean up well to good users.
2. Sharpen them. Just sharpen the cutting lips and the inside of the spurs. If you sharpen the outside of the spurs without understanding the cutting geometry of an auger bit you will decrease the diameter that the spurs cut and the bit will bind in the hole. If you spin the auger against some abrasive paper and keep it flat, you will maintain the proper clearance diameter. Also make sure to maintain the clearance angle on the front side (side towards the wood you’re going to cut) of the cutting lips. Most advice will say to leave that side completely alone and just sharpen the bevel.
3. Clean and polish the lead screw. I like to use a brass brush by hand, not in a buffer to be more gentle. Then screw the lead screw into a scrap piece and press some polishing compound into the hole then screw the lead screw in and out many times and it will polish the threads.
You can chase the threads with a 3 corner file or needle file, but it is challenging to keep the right angles and spiral. Again, any that need this are typically more work than they are worth.
Cotton sash cord with compound is a great idea to clean the spiral part of the auger away from the lead screw, I’ll have to try that.
View Ron Aylor's profile
Ron Aylor
2631 posts in 670 days
#4 posted 06-13-2017 08:21 PM
I would soak them in vinegar over night then tune-up with an auger file …
-- Ron in Lilburn, Georgia.  https://ronaylor.wordpress.com
Smitty_Cabinetshop
15367 posts in 2640 days
#5 posted 06-13-2017 09:13 PM
I’d wipe each of them thoroughly with a WD-40 soaked rag to get them coated, and use them.
View papadan's profile
papadan
3584 posts in 3390 days
#6 posted 06-13-2017 09:34 PM
I d wipe each of them thoroughly with a WD-40 soaked rag to get them coated, and use them.
- Smitty_Cabinetshop
+1 Using them on some scraps is an easy way to really clean them. Heavy rust spray a little WD40 and let soak for a while, then use.
View Jim Jakosh's profile
Jim Jakosh
20587 posts in 3128 days
#7 posted 06-14-2017 02:19 AM
Apple cider vinegar will take the rust off. Soae them for a day in it but it might turn the shafts black but they will be clean an usable.
Jim
View Mr_Pink's profile
Mr_Pink
85 posts in 394 days
#8 posted 06-14-2017 03:17 AM
I went through this several months ago and made the mistake of neglecting #3 on Tim’s list above. Don’t do that. I almost gave up on a set of perfectly serviceable bits (complete with a nice box). I thought they weren’t cutting because something was wrong with the parts of the bits that actually cut. Out of desperation, I decided to follow directions and polish the threads of the lead screw. Now the bits work fine.
BenDupre
#9 posted 06-14-2017 05:12 AM
Thanks for the advice all. Fwiw these Russel Jennings bits cut really well. I have some craftsman augers it seems to take a lot more effort to bore with them. I sharpened those and it helped a little but the lead screw wants to strip the hole and then the bit stops feeding. That hasnt happened in any of the test holes i made with the RJs.
Also BTW in case any one has a comment: it took me quite a while to score a full set on the bay. Aparently there is quite a market for these. The boxed sets are going for a hundred plus bucks. I saw a set in a canvas roll stencilled U.S. ROLL, CANVASS,WOOD BORING AUGER BITS go for a hundred seventy five. Probably went up San Juan hill with TR and the Rough Riders.
These are in a vinyl roll probably 1960s vintage.
View WayneC's profile
WayneC
13754 posts in 4119 days
#10 posted 06-14-2017 09:37 PM
My favorites. Have both 100 and 101 sets in boxes.
View TheFridge's profile
TheFridge
9603 posts in 1508 days
#11 posted 06-14-2017 11:17 PM
Difference between the 2? Coarse & fine leadscrew?
View theoldfart's profile
theoldfart
9737 posts in 2473 days
#12 posted 06-15-2017 12:21 AM
yup
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
