I hate it when kickbacks happen.
Forum topic by GoodwithWood posted 06-13-2017 02:39 PM 1100 views 0 times favorited 22 replies Add to Favorites Watch
View GoodwithWood's profile
GoodwithWood
36 posts in 636 days
06-13-2017 02:39 PM
-- "what a ya mean I don't believe in god, I talk to him every day.” Dave Mustiane.
22 replies so far
GoodwithWood
#1 posted 06-13-2017 02:41 PM
View WayneC's profile
WayneC
13754 posts in 4125 days
#2 posted 06-13-2017 02:44 PM
Ouch
View GR8HUNTER's profile
GR8HUNTER
4007 posts in 740 days
#3 posted 06-13-2017 02:46 PM
OUCH YES …...but with mine was no exit hole …..:<((
View rayn's profile
rayn
174 posts in 3246 days
#4 posted 06-13-2017 02:57 PM
14 stitches to the top of my left hand from a small piece of 1/8” baltic birch plywood…...Then I checked the alignment of my fence
Ray
-- Ray,Iowa
GoodwithWood
#5 posted 06-13-2017 03:18 PM
Ya Ray, On this one I was doing work on anothers’ tablesaw using a push stick, it went through my shorts and a piece of plywood 16’ away.
Upon further examination the blade insert was for dado blades. I should have seen it.
I always stand just to the left of the potential kickback area, as you can see this one was close.
View Madmark2's profile
Madmark2
379 posts in 616 days
#6 posted 06-13-2017 04:51 PM
Stand to the left of the blade or right of the fence …
M
View helluvawreck's profile
helluvawreck
31407 posts in 2894 days
#7 posted 06-13-2017 05:06 PM
Even though what happened was bad enough at least it wasn’t a serious disaster that put you in a hospital for days or weeks. I hope you heal up quickly.
helluvawreck aka Charles
View rwe2156's profile
rwe2156
2967 posts in 1508 days
#8 posted 06-13-2017 06:23 PM
1/4” plywood is the worst. A splitter is a must for not other reason it keeps you from removing the wood till it clears the blade.
I’ve also caught the top of a spinning blade on the bottom of the wood cause I didn’t lift it high enough.
MadMark—yeah but sometimes you have to stand right behind the blade.
BTW all SS owners: this is (probably at least for me) the most common TS injury & your saw won’t prevent it.
View UpstateNYdude's profile
UpstateNYdude
917 posts in 2011 days
#9 posted 06-13-2017 07:43 PM
BTW all SS owners: this is (probably at least for me) the most common TS injury & your saw won t prevent it.
- rwe2156
Please don’t start this up again, I beg you just let it be.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
View jimintx's profile
jimintx
802 posts in 1612 days
#10 posted 06-13-2017 07:49 PM
GoodwithWood, I can’t say that I really understand the opening photo posted.
Are you showing us two projectile paths that occurred to you at the same time, one through your shirt and a second through the pants?
-- Jim, Houston, TX
View onoitsmatt's profile
onoitsmatt
392 posts in 1204 days
#11 posted 06-13-2017 07:57 PM
I suspect shirt was tucked into pants.
Glad it wasn’t worse. Broke my thumb due to kickback. Because I was stupid.
-- Matt - Phoenix, AZ
GoodwithWood
#12 posted 06-13-2017 10:32 PM
The shirt you all are talking about is actually the boxer shorts that were underneath the khaki shorts.
Get it now?
View Redoak49's profile
Redoak49
3287 posts in 2016 days
#13 posted 06-13-2017 11:05 PM
I am very glad you were not hurt worse and it did not target another area of your shorts
Can you tell a bit more..
What type saw…
What type blade
Riving knife or splitter
Blade guard or anti-kickback pawls
Saw guard
For me, I I use a Grripper for narrow stuff like that so I can control a thin cut off between the blade and fence
View Woodmaster1's profile
Woodmaster1
984 posts in 2615 days
#14 posted 06-13-2017 11:41 PM
When I taught woodworking a great example was to point to the dent in the block wall. I still remind the guy about it 40 years later.
View unbob's profile
unbob
810 posts in 1931 days
#15 posted 06-14-2017 12:41 AM
“MadMark—yeah but sometimes you have to stand right behind the blade.”
A very bad idea, not nessesary, and not worth the risk of being killed.
