Poly on Danish Oil
Forum topic by Don Johnson posted 12-04-2010 01:21 PM 1445 views 0 times favorited 4 replies Add to Favorites Watch
View Don Johnson's profile
Don Johnson
683 posts in 2715 days
12-04-2010 01:21 PM
Topic tags/keywords: question
I see many references to ‘poly’ as a finish for projects. Does this mean polyurethane varnish ?
If so, I am surprised that it is mentioned as being used AFTER Danish Oil – I would not have expected it to ‘take’ on an ‘oily’ surface.
Or have I got it completely wrong?
-- Don, Somerset UK,
View b2rtch's profile
4851 posts in 2982 days
#1 posted 12-04-2010 03:47 PM
Hey Don, I found this other forum for you which give an answer to your question
(good question by the way):
I hope this help
-- Bert
View Gene Howe's profile
Gene Howe
10260 posts in 3362 days
#2 posted 12-04-2010 03:54 PM
Sure, you can apply most any finish over fully cured Watco or “Danish Oil”. You can even mix oil based finishes with Watco to make a wiping varnish.
View Maveric777's profile
2693 posts in 3010 days
#3 posted 12-04-2010 04:27 PM
The key (from my little experience) is to make sure the danish oil is “Cured” before applying the poly. Ihave done it and yes it does work. I too was sceptical until I read it on the back of the label….lol. I think I waited something like 2 weeks before attempting the poly. May be over kill, but I didn’t want to risk it.
-- Dan ~ Texarkana, Tx.
16273 posts in 4152 days
#4 posted 12-04-2010 04:39 PM
If you do put the poly on before the Danish oil is cured, don’t panic. The project will feel sticky, but will eventually dry in a month or so.
