Untrue spade bits
Forum topic by JoshNZ posted 06-13-2017 12:45 AM 1196 views 0 times favorited 32 replies Add to Favorites Watch
View JoshNZ's profile
JoshNZ
122 posts in 1270 days
06-13-2017 12:45 AM
Topic tags/keywords: tools spade bits drill bent
Just bought a set of spade bits from the local hardware store in town and just about all of them seem untrue. I wanted to get a second opinion from you guys before I kicked up any stink about it. See attached video and tell me what you think please! Is this acceptable for spade bits? I realise they aren’t a precision tool but is this taking the piss?
Thanks!
https://www.youtube.com/embed/Y07Rz7v_GUk
32 replies so far
JoshNZ
#1 posted 06-13-2017 12:47 AM
I should add I chucked up a high quality drill bit to check it ran true, and it did, and I chucked the spades in another drill to check I had the same problem, and I did :/.
View Jimintomahawak's profile
Jimintomahawak
73 posts in 676 days
#2 posted 06-13-2017 12:56 AM
It appears they are bent or your chuck may have problem. Since you checked multiple chucks bent is more likely. Check chucks with a steel dowel pin or twist drill to double verify chucks are ok.
-- Laziness drives creative thinking...
View TheFridge's profile
TheFridge
10718 posts in 1686 days
#3 posted 06-13-2017 01:02 AM
I wouldn’t care one bit personally. A forstner or bit from a drill index I would.
View Sark's profile
Sark
82 posts in 561 days
#4 posted 06-13-2017 01:05 AM
Yeah, cheap spade bits. I’d take them back. I find cheap spade bits are almost always bent and dull, and of soft steel. The local hardware may not have quality spade bits. But your hardware store probably has something you want so you can trade in on something of value, if they won’t just refund.
JoshNZ
#5 posted 06-13-2017 01:11 AM
I have checked other bits in the chucks as I said, they do run true. It’s a dewalt drill, never had a problem with any other bits. I opened the kit and used the 16mm bit first and the whole drill/work piece chattered.
I will send the video to them and see what they think
View mudflap4869's profile
mudflap4869
1874 posts in 1659 days
#6 posted 06-13-2017 01:31 AM
I detest spade bits. I let my wife keep the ones she owns, but I stick to Forstner bits exclusively. They stay true even if they are gotten into a bit of a bind.
-- Still trying to master kindling making
View AlaskaGuy's profile (online now)
AlaskaGuy
4786 posts in 2509 days
#7 posted 06-13-2017 02:18 AM
Yes it could be the chuck. Watch this video.
https://youtu.be/a-PM2D2Vt7s
How ever it be this
They both make holes. A spade or paddle bit is about like a chainsaw, where a Fortsner bit is more like a table saw with a good blade. If you just need a hole, not very precise and spade bit will do, but if you need a consistent diameter hole with smooth sides, use the Fortsner.
If you are running wires through floor joists, that might be were you would use a spade bit. If you are making holes for dowels or round tenons that’s where the Forstner would be best.
AlaskaGuy
#8 posted 06-13-2017 02:39 AM
Deleted wrong website :)
View BlasterStumps's profile
BlasterStumps
984 posts in 640 days
#9 posted 06-13-2017 02:59 AM
That makes two of us that detest spade bits. I can do a fair job at sharpening Forstner bits so I think I will stick with them.
- mudflap4869
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View BenDupre's profile
BenDupre
683 posts in 688 days
#10 posted 06-13-2017 03:33 AM
For spade bits try Irwin. Or Bosch makes a set that have the old school feed screw in the end. Haven’t tried them yet but looks like the sh!t. Anyhow… the thing with those spade bits is the point indexes it in the hole so it will probably drill true and maybe shake a little. I would bet the wobbliness you’re seeing might be an optical illusion.
Having said all that, fostner bits or augers are going to always perform better.
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
View Dark_Lightning's profile
Dark_Lightning
3342 posts in 3309 days
#11 posted 06-13-2017 03:41 AM
Spade bits are for drilling holes in lumber that has no accuracy requirement, and that’s about it.
-- Random Orbital Nailer
View Ron Aylor's profile
Ron Aylor
2649 posts in 848 days
#12 posted 06-13-2017 11:21 AM
Spade bits are for drilling holes in lumber that has no accuracy requirement, and that s about it.
- Dark_Lightning
I disagree … but then again, I’m using a slightly different drill … SEE Here
View ScottM's profile
ScottM
691 posts in 2347 days
#13 posted 06-13-2017 01:23 PM
You said ”... bits from the local hardware store in town.” It wasn’t Harbor Freight, was it? I only buy drill bits there in a serious pinch. Gotten several that were all wonky out of the wrapper.
View WayneC's profile
WayneC
13786 posts in 4298 days
#14 posted 06-13-2017 01:27 PM
I would just use a bit brace. Not bother with spade bits.
BenDupre
#15 posted 06-13-2017 01:32 PM
These are 10 bucks. I havent yet but why dont you give them a try? They have a lead screw instead of a point like the old brace augers.
Bosch Daredevil
showing 1 through 15 of 32 replies
