Need Super Durable Finish suggestions for Plywood box
Forum topic by lorne17 posted 06-13-2017 12:38 AM 3339 views 0 times favorited 27 replies Add to Favorites Watch
View lorne17's profile
lorne17
13 posts in 3623 days
06-13-2017 12:38 AM
Topic tags/keywords: plywood finish waterproof outdoor
Hello there,
I am making an outdoor camping chuckbox (see what I am talking about here: http://blog.rei.com/camp/how-to-build-your-own-camp-kitchen-chuck-box/) out of balsa plywood. It’s super light ply, but it’s super porous. So I’m trying to figure out what product to coat the entire box in to make it basically impenetrable!
My first thought, was spray paint with an outdoor clear spray paint that protects it. Then I didn’t think that’d be good enough as this will be standing on legs that will move and drag in dirt and rocks in the forest and likely scratch the finish and then suck water in!
My second thought was a truck bed liner, those things are super tough and durable. But I read that they likely would be difficult to clean. Since I’m using this for a camp “kitchen” there will be food, etc that gets on it so I’d like to keep it so I can easily clean it.
My latest thought is to do a poured resin over it. However with all the undulations of surfaces, etc, I figured this may be difficult to ensure everything is coated and covered. Plus this resin is expensive!
So with all that said, what do you suggest? I’m open to anything at this point. Granted, I don’t want to spend a ton, but I also want to protect it to avoid wasting all the hard work in making this box.
Thanks in advance!
Lorne
-- "A great woodworker hides their mistakes well."
27 replies so far
View ArtMann's profile
ArtMann
1044 posts in 935 days
#1 posted 06-13-2017 01:13 AM
Oil enamel paint?
View StephenO's profile
StephenO
44 posts in 2664 days
#2 posted 06-13-2017 02:20 AM
Maybe something for hardwood flooring…
-- -Steve, Seattle
View gmc's profile
gmc
57 posts in 2275 days
#3 posted 06-13-2017 12:17 PM
I would use a stain/dealer as you assemble it. Make sure you let it soak in and seal everything. Then use an oil based poly for the protective coating. The sealer would insure you get all the wood pours sealed from absorbing anything and the poly would add a layer of protection from dings and scratches. You could use any type of poly but you want it thick to protect it. Just my thoughts on how to do it and keep the cost down. I figure you know not to seal where you are going to glue until the joints have dried.
-- Gary, Central Illinois
5069 posts in 2612 days
#4 posted 06-13-2017 01:16 PM
First, what you want to do isn’t possible…at least not with the finishes available to us mere mortals (IMHO, of course). Second, a good coat of an oil based exterior paint would be as good as it gets….and better than almost all other common choices. I’d use a primer (also oil based exterior) and then maybe 3 coats of the paint. I would not use an oil based paint on the inside, however…it will smell for a very long time. For that a good 100% acrylic will have to do.
lorne17
#5 posted 06-13-2017 02:00 PM
Thanks for all the responses all.
GMC – unfortunately most of it is already assembled! Oops!
Fred – I agree, there is no product that will be perfect, however I feel I can get something that will be close and protect it longer and stronger than other products.
Finally, I was also thinking of doing a garage floor epoxy paint. Before I do that I will sand the box, caulk all the joints and corners. Then coat it in epoxy. Something like this: https://www.amazon.com/1-Part-Acrylic-Interior-Exterior-Concrete/dp/B01M9IQH10/ref=sr_1_1?ie=UTF8&qid=1497362242&sr=8-1-spons&keywords=garage+floor+epoxy#customerReviews
Or something like this: https://www.amazon.com/dp/B06XPZQHHB/_encoding=UTF8?coliid=I36FOEVNG83ES9&colid=1XRJ0Z22FCBEL&th=1
Thanks,
Lorne
View ScottM's profile
ScottM
671 posts in 2265 days
#6 posted 06-13-2017 02:26 PM
Take a look at epoxy bar top finishes.
View Rich's profile
Rich
3543 posts in 708 days
#7 posted 06-13-2017 03:57 PM
I like your and Scott’s idea of epoxy — either paint or bar top. Also, it would seem to me that some type of steel corner protectors might help the overall durability.
View dday's profile
dday
164 posts in 1548 days
#8 posted 06-13-2017 04:16 PM
All of these suggestions are good.. for the “food” bearing surfaces ( those likely to get splashed upon or worked on) have you considers covering them with a thin, stainless sheet? It could be bent around any corners and it would be easy to keep clean and stain free.
View Bluenote38's profile
Bluenote38
337 posts in 507 days
#9 posted 06-13-2017 04:42 PM
Marine plywood and Marine Spar Varnish. Both are specially formulated to survive for an extended period around humid salt environs. The surface will chalk when it starts to fail (this is a UV failure). Lightly sand off the chalk and revarnish. On a boat that’s 2-3 years on the deck. Or build with teak and apply teak oil annually
-- Bill - Rochester MI
View TheFridge's profile
TheFridge
10106 posts in 1605 days
#10 posted 06-13-2017 05:01 PM
Carbon fiber layering with nanotechnology.
View jbay's profile
jbay
2592 posts in 1018 days
#11 posted 06-13-2017 05:13 PM
- TheFridge
+1 Since your going to be floating it down the river, I see no other way :)
lorne17
#12 posted 06-13-2017 06:35 PM
Thanks for everyone’s comments! While I wish I can do some suggestions, they are out of reach ;). But floating down a river would be perfect!
Also marine plywood is out of the question since it’s mostly already built. But good to think of for future projects. Weight would be something to consider however.
What steel edging do you recommend I used for the corners/etc? Perhaps I can get aluminum trim pieces to protect it but also keep weight down.
Here’s an image of what my project will be:
Thanks,
Lorne
View Rich's profile
Rich
#13 posted 06-13-2017 07:09 PM
When I mentioned the corner protectors, I was thinking about something like this. I’m sure something similar could be had in aluminum.
However, looking at your design, it’s hard to see where they would be useful. I was picturing a box with corners like the one in the link you posted.
lorne17
#14 posted 06-13-2017 07:19 PM
Yea, you’re right I don’t think those would work. I was planning on using Plasti-Dip on the feet for dragging around, etc. Maybe instead I just get steel/aluminum angles to cover the feet.
https://www.amazon.com/Aluminum-U-Channel-Unpolished-Lengths-Thickness/dp/B00CNLYMXU/ref=sr_1_1?ie=UTF8&qid=1497381517&sr=8-1&keywords=aluminum+U+channel+1%2F2%22
View jbay's profile
jbay
#15 posted 06-13-2017 07:33 PM
They do make lexan corner protectors.
Just a site I googled..
