Wood kitchen sink- Can it be done?
Forum topic by StumpyNubs posted 12-04-2010 02:22 AM 27340 views 3 times favorited 24 replies Add to Favorites Watch
View StumpyNubs's profile
StumpyNubs
7598 posts in 2822 days
12-04-2010 02:22 AM
I have made my mind up. As part of my complete kitchen remodel, I am making a wood kitchen sink. I know it’s possible because I’ve seen some websites selling beautiful wooden sinks for the bathroom, even bath tubs. So there’s no reason to believe the idea couldn’t be applied to a kitchen sink.
My idea is a farmhouse style with two basins. I haven’t decided on the wood, which is why I am posting this thread. The sinks I’ve seen are made of teak. But I want something more interesting. I know some types of wood are water resistant and even resist bacteria, like teak and paduk. But does the type of wood make as much of a difference as the type of finish?
And what kind of finish would that be? It would have to withstand not only water, but spills of kitchen messes like hot grease, all while making the seams water tight.
Any ideas?
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
24 replies so far
35125 posts in 4422 days
#1 posted 12-04-2010 02:57 AM
Jim Here is a web site on wooden Kitchen sinks.
And here is a post on woodweb.
View twissty's profile
twissty
26 posts in 2874 days
#2 posted 12-04-2010 05:40 AM
Maybe something like a marine epoxy to coat all sides of the wood.
You could even add a layer of fiberglass cloth and clearcoat it with epoxy. The final product would be as tough as an acrylic or fiberglass sink. and pretty much maintenance free
View WoodLe's profile
WoodLe
155 posts in 2818 days
#3 posted 12-04-2010 05:49 AM
2nd what twissty said. Fiberglass cloth and epoxy are wonderful products. It’s what I used on my wood strip canoe that I have listed in ‘my projects’. Totally waterproof.
-- www.largewoodslabs.com Wooster, Ohio
View Dark_Lightning's profile
Dark_Lightning
3163 posts in 3131 days
#4 posted 12-04-2010 05:54 AM
Solutions so far seem to rely on the wood for the structure only. Is that what you are after?
I’d personally rely on a ceramic finish, which, for me, means cast iron or fiberglass. But that’s up to you.
-- Random Orbital Nailer
View grizzman's profile
grizzman
7836 posts in 3325 days
#5 posted 12-04-2010 06:02 AM
well jack i think he wants to see the wood…wouldn’t your idea cover up the wood…i didnt know there were such things as wooden sinks…this will be interesting to see come about…good luck…grizzman
-- GRIZZMAN ...[''''']
StumpyNubs
#6 posted 12-04-2010 02:54 PM
I don’t want to cover the wood with anything, that would defeat the purpose. I suppose fiberglass could go on the underside, but I don’t think there would be any need for something to reinforce or strengthen it, wood should be quite strong.
The issue is a durable finish that will withstand a beating as well as cooking spills and stay looking good.
View Steven Davis's profile
Steven Davis
118 posts in 2936 days
#7 posted 12-04-2010 07:42 PM
You might want to look at woods used for boats – same problem, just keeping the water “in” instead of “out”.
-- Steven Davis - see me at http://www.free2secure.com/
View Div's profile
Div
1653 posts in 2962 days
#8 posted 12-04-2010 09:16 PM
Firstly you want a very stable wood which is why teak is a good choice. A penetrating epoxy like WEST will make for a dueable finish.
I couldn’t(wouldn’t?) afford teak and didn’t feel like the sticky stuff. My double sink is made from selected old growth tightly grained quartersawn PINE! I oiled the hell out of it with boiled linseed oil. It must be soaked right through! The whole thing is experimental but so far it is doing well. I used a waterproof polyurethane glue for the laminations, it was built in layers to get large rounded corners. Resorcinol glue would be excellent as well, didn’t have any at the time.
-- Div @ the bottom end of Africa. "A woodworker's sharpest tool should be his mind."
117114 posts in 3599 days
#9 posted 12-04-2010 09:26 PM
I would suggest Epi it will hold up to water with out a finish and is very hard it’s even fire rated.
View JasonWagner's profile
JasonWagner
527 posts in 3202 days
#10 posted 12-04-2010 09:44 PM
correction – Ipe
You can coat with fiberglass and still see through right?
-- some day I hope to have enough clamps to need a clamp cart!
WoodLe
#11 posted 12-05-2010 12:36 AM
Jim, If you’re not familiar with fiberglass cloth and epoxy, look at how to make wood strip canoes. Looks just like varnish with beautiful wood showing through!
StumpyNubs
#12 posted 12-05-2010 02:20 AM
Div- you have actually made a sink from wood? Is it used in the kitchen?
I know teak will work, but price is always an issue. Plus, I really want something unique, perhaps an exotic like zebrawood. I wonder if you could build the sink out of a hardwood like maple, or even a softwood like pine and laminate 1/4” thick “veneer” over it with a much more expensive, more beautiful wood? If it’s all coated with a sealer, should’t it work?
StumpyNubs
#13 posted 12-05-2010 02:21 AM
WoodLE- I am not familliar with the fiberglass process for kayaks. Does it leave a smooth, clear surface like a glossy finish would or does it look like the wood is covered with fiberglass?
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2878 days
#14 posted 12-05-2010 02:56 AM
Jim, there is another way using resins, thin like CA. Using a vacuum pump. If you get extremely dry wood Zebrano is good. The vacuum pulls out the air from the wood then the resin gets in. I think it is also called stabilised wood. What is nice about this method is that you can have a mat finish.
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
#15 posted 12-05-2010 06:08 AM
Thanks Jason I guess my dyslexia kicked in. It is Ipe a common deck material .
http://www.woodsthebest.com/ipe_decking/ipe-wood.htm
