help with new table saw
Forum topic by buckbuster31 posted 06-12-2017 07:53 PM 423 views 0 times favorited 6 replies Add to Favorites Watch
View buckbuster31's profile
buckbuster31
254 posts in 635 days
06-12-2017 07:53 PM
I have around 1200 to spend. Im really in the market for a new one due to not wanting to have to deal with a used. I am considering the the grizzly hybrid. Any other recommendations?
View bbasiaga's profile
bbasiaga
1240 posts in 2114 days
#1 posted 06-12-2017 08:05 PM
120 or 220V power?
I think Laguna and Jet have some saws in that price range. The Grizzly 690 or 1023 can be had for close to that sometimes.
Brian
View TheFridge's profile
TheFridge
10110 posts in 1605 days
#2 posted 06-12-2017 08:08 PM
Save a couple more buck and get a cabinet saw with a better fence.
buckbuster31
#3 posted 06-12-2017 08:13 PM
120 or 220 are both fine. Just started building a 30×40 building that will have a fairly large wood shop in it.
View knotscott's profile
knotscott
8122 posts in 3495 days
#4 posted 06-12-2017 08:16 PM
If you have 220v, and can save a couple hundred more, the Grizzly G1023RL or G0690 are distinct step up from any of the hybrids….much beefier under the hoods. Both are a lot of saw for the money.
The Jet Proshop is arguably the best of the $1200 hybrids….cabinet mounted trunnions, cast arbor carriage, nice fence, well proven, etc. The Laguna Fusion has similar guts under the hood, but it uses a two-piece aluminum fence rail vs steel on the Jet. Either of the Grizzly hybrids are a good bang for the buck too.
knotscott
#5 posted 06-12-2017 10:08 PM
p.s.: If you’re wiring a new shop, definitely install 220v (aka 240v). ...it’ll allow you to run bigger motors, and the wire may cost a bit less.
View WhyMe's profile
WhyMe
1049 posts in 1680 days
#6 posted 06-13-2017 02:10 AM
No… It’s 240V,. wrongly called 220V. :-)
