filling a hole in a slab wood project
Forum topic by chrisagnew posted 12-04-2010 12:53 AM 5849 views 0 times favorited 8 replies Add to Favorites Watch
View chrisagnew's profile
chrisagnew
15 posts in 3633 days
12-04-2010 12:53 AM
Folks:
I have purchased some decent looking hickory to make a slab style coffee table. The pieces have some oblong holes in it where knots are etc.
They are not huge but they need to be filled in with something. Im sure others here have come across the same problem and I am hoping they will share with me what they used to fill the gap. Epoxy? Wood filler
I am open to any suggestions.
thanx in advance
Chris
8 replies so far
View DaddyZ's profile
DaddyZ
2475 posts in 2948 days
#1 posted 12-04-2010 12:55 AM
I would use Epoxy with some sawdust.
View Gregn's profile
Gregn
1642 posts in 2891 days
#2 posted 12-04-2010 01:18 AM
A Dutchman/Butterfly patch might be a better solution than using just filler or epoxy. It would also allow you to use contrasting wood for the patches to make it even more interesting.
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3014 days
#3 posted 12-04-2010 02:36 AM
Ditto on epoxy and sawdust.
View Lumber2Sawdust's profile
Lumber2Sawdust
139 posts in 2773 days
#4 posted 12-04-2010 06:32 PM
It really depends on the look you want. If you want to patch the holes and minimize the appearance, then the epoxy/sawdust method would be good.
If you want to highlight these “features” of the wood, you could fill them with an epoxy colored to contrast with your project.
My first thought is more in line with Greg – use a butterfly key, or other small inlay to cover the hole. I did this on a workbench project recently which has some defects I wanted to smooth out. I patched the maple top with walnut diamond-shaped inlays. They are pretty easy to do, you can make any shape you want, and can give you a nice contrast. If you go this route, you would still want to fill the hole behind the inlay so that it stabilizes the wood you put over the top.
View rance's profile
rance
4256 posts in 3068 days
#5 posted 12-04-2010 08:19 PM
All good suggestions. Also I saw a guy route out a loose knot. He then found a similar shape/size tight knot and inlayed it. Looked cool. And yeah, ladies can do this just as good as guys can. :)
View swirt's profile
swirt
2553 posts in 2879 days
#6 posted 12-05-2010 05:55 AM
If you are looking for something more outside the woodworking box, I’ve seen some nice work done with inlaying a natural stone or even a glass marble. I’m not sure what look you are shooting for so it is hard to say for sure.
View Jim Finn's profile
Jim Finn
2622 posts in 2830 days
#7 posted 12-06-2010 02:14 AM
I have used “Z-Poxy” with crushed colored chalk mixed in it.
View TheWoodsman's profile
TheWoodsman
65 posts in 2804 days
#8 posted 12-06-2010 05:31 AM
Epoxy is your best bet because it can be filled all at once and doesn’t shrink as it dries. Adding sawdust will not make it match. I would recommend using it as sort of a “design element”. Add some colorant or powder to it.
Though they use other materials and processes these guys may give you some ideas.
http://andysanchez.com/AndyandAaron/HTML/coffeetables.html
-- I'm the Woodsman . . . the four-wheelin', tree-farmin', custom-furniture-makin' descendant of Olaf "The Woodcutter" Ingjaldsson.
