Anyone ever turn door knobs?
Forum topic by chrisstef posted 12-03-2010 09:57 PM 1072 views 0 times favorited 2 replies Add to Favorites Watch
View chrisstef's profile
chrisstef
17312 posts in 2976 days
12-03-2010 09:57 PM
I have recently just installed some new french doors in the house and the wife and i have been on the search for dummy knobs. Id really like to go with glass knobs for nostalgias sake but they are pretty expensive, especially for 8 of them. So having a woodworking mind, has anyone ever turned their own door knobs?
These will need to be double dummy knobs at the same level on each side. I was thinking that i could use dowel fasteners like for stair ballusters that are threaded on both ends to attach them together through the door.
2 replies so far
View richgreer's profile
richgreer
4541 posts in 3044 days
#1 posted 12-03-2010 10:37 PM
I’ve turned a doorknob. It came out pretty good.
The challenge will be making them consistent. Since I only made one, that was not a challenge for me.
If I were turn more than one I would cut a profile out of some scrap plywood or hardboard and use that to guide me with each one. I don’t think I would hesitate to take on a project of making 8 consistent doorknobs.
You can always try one or two and see how it goes before proceeding.
My procedure – - Start with a block of wood measuring 2” x 2” x 3.5”. Drill a 3/8” hole 3” down through the block of wood. Make this hole as centered and as square as possible (a jig might help). Mount the hole end of the block into a chuck on the lathe. Turn the doorknob. Cut off with a saw. (I used my bandsaw, but any saw will work). Glue dowel into hole. Drill 3/8” hole in door and mount with glue.
I did mine in cocobolo. It is beautiful!
View shipwright's profile
shipwright
7967 posts in 2767 days
#2 posted 12-04-2010 04:44 AM
I like wooden door knobs. I’ve almost always had them on my shops. I even had one on my front door once. This is my front shop door set currently. The chains pull sprung latch bolts top and bottom.
