Delta 22-540 planer parts free to those in need
Forum topic by Stevethornton posted 06-11-2017 10:00 PM 2991 views 0 times favorited 14 replies Add to Favorites Watch
View Stevethornton's profile
Stevethornton
1 post in 435 days
06-11-2017 10:00 PM
Topic tags/keywords: delta planer 22-540
Gearbox on my Delta 22-540 planer bit the dust. Not able to locate one as they are obsolete…..rest of planer is still functioning.
If you are in need of any parts please contact me and I will ship on your dime.
Got it in scrap pile, but would rather help a brother or sister out.
If this is posted in wrong location please move to correct location. Long time lurker here but first time posting.
14 replies so far
View Pete8343's profile
Pete8343
2 posts in 433 days
#1 posted 06-14-2017 02:45 AM
Stevethorton I just pulled apart a 22-540 i thought I got on a good deal at a sale for a 100 bucks. Bought bearings thinking this would fix it up but there is more. It needs both rollers, a cutter head pulley and I m not sure the if keyway in the cutter head has been damaged. Its either I pull the gear box and send it to you or you send me parts. I have yet to take the gearbox apart and inspect it. Where are you located? This planner is getting real close to the junk pile because of costs.
Thx Pete
Pete8343
2 posts in 433 days
#2 posted 06-14-2017 05:13 PM
Steve. Contact info. Mepeter@yahoo.com
View grantdesrosiers's profile
grantdesrosiers
1 post in 358 days
#3 posted 08-27-2017 11:32 PM
Hey Steve, what exactly happened to your gearbox (if you still have it)? I have the same planer with a busted gear
View delta540C's profile
delta540C
1 post in 267 days
#4 posted 11-27-2017 12:11 AM
Steve – please contact me: mtebokkel@gmail.com
View pududu's profile
pududu
1 post in 224 days
#5 posted 01-09-2018 03:12 AM
OK, new here, and on a mission.
I have a 22-540 Type 1 from ‘93 and need new knives. Unfortunately I turned my old ones over to a buddy who incorporated them into a knife he forged. My cutterhead measures 12 5/8 wide, table 12 3/16” wide, looking at markings on cutterhead my knives appeared to have been 12 1/2”. Problem-the 22-547 knives measure 12”. I can stagger them to cover the table but then only 1 knife will hit the very outside of the table instead of 2. Delta support says my head should measure 12 1/8”, knives 12 1/16”. Been a long time since I purchased knives and don’t recall, but 12 1/16” doesn’t feel right.
Thoughts?
Stan
View Jim3's profile
Jim3
3 posts in 76 days
#6 posted 06-06-2018 01:38 AM
Hey Steve, still parting out the Delta 22-540? I need Leveling Handle Assy , item 4 on the parts diagram.
Please email me jim.regan@nasco.com
Thanks
View Verchal's profile
Verchal
1 post in 68 days
#7 posted 06-14-2018 12:46 AM
One of my gears is bad on my 22-540 Delta(#27.) Does anyone know where I might be able to get one? It is no longer stocked. I guess my only chance is that someone else has one with a bad motor and good gears that is willing to part it out. I need the blade setter as well, but not if I can’t find a replacement gear. Thanks everybody,
Kevin
View Jim3's profile
Jim3
3 posts in 76 days
#8 posted 06-14-2018 02:21 AM
Kevin, someone told me a few years ago when Delta Machinery was sold the new owner disposed of all the old machine parts. I suppose they thought people would buy new equipment. I suspect the gear you need is a standard off the shelf part if you can identify another machine with uses the same gear.
As an alternative would anyone else on the thread be willing to part out their non-functional planer?
View Woodknack's profile
Woodknack
12243 posts in 2466 days
#9 posted 06-14-2018 05:23 AM
I traded emails with the OP, Steve, back when he originally posted this and the guy is super busy in life and I think he decided it wasn’t worth his time. I have no idea what happened to the parts. We traded emails for awhile and I was going to drive down to pick up the parts and he stopped communicating. Maybe he found someone local.
Best use for these old Deltas might be to sell the parts to someone who wants to build a 12” jointer, or build one yourself. I have one and that’s what I plan for it. It sucks you can’t buy parts but it is what it is.
View Kazooman's profile
Kazooman
1090 posts in 2038 days
#10 posted 06-14-2018 02:35 PM
Thanks
- Jim3
I used to own one of these and the handle on mine also failed. As is the case for most older Delta machinery the part is obsolete and I could not find a replacement. I was able to make the handle functional again at the cost of losing the fold-over for storage feature. A few carefully drilled holes with pins inserted and a liberal coating of J B Weld and it works. I gave the planer away to a friend when I purchased a Dewalt DW735, so I cannot take any pictures to show you the repair. Have a hard look at yours to see if you cannot restore it well enough to make the planer usable again.
View Olywa's profile
Olywa
1 post in 42 days
#11 posted 07-09-2018 01:55 PM
Steve,
If you still have parts available, I would love to get a hold of a chain sprocket. I think all 4 sprockets are identical. Please let me know if this is a possibility. Thanks.
Pat Duff
pduff@cwclaw.com
View Harryn's profile
Harryn
70 posts in 2674 days
#12 posted 07-12-2018 08:18 PM
For what it’s worth, I found 12 1/2 Porter Cable blades fit my Delta 22-560 planer cheaper too. bot e’m at Lowes
View Geezie's profile
Geezie
1 post in 38 days
#13 posted 07-13-2018 02:01 PM
I am in need of a drive belt.Do you have one?
View Jim3's profile
Jim3
3 posts in 76 days
#14 posted 07-14-2018 03:07 AM
The new planers build by Rikon and others look like exact duplicates of the Delta. I bet the belts are interchangeable
