Sanding the insided of small boxes
Forum topic by leonmcd posted 281 days ago 185 views 0 times favorited 8 replies Add to Favorites
View leonmcd's profile
leonmcd
177 posts in 500 days
281 days ago
Topic tags/keywords: sanding small box tray bit
I’m working on a small box. Inside deminsions about 3” across and 1 1/4” deep. It was hollowed out with a tray/bowl router bit with a 3/4” diameter and a 1/4” radius. It is heart shaped (late Valentine’s gift) so no corners to deal with.
I’m looking for the best way so sand the interior. I’m thinking in terms of a drum sander I can use in my drill press but I need a soft rounded bottom (no comments please) . I’ve seen soft sanding systems for bowls to use on a lathe but the smallest seem to be 2” across.
I’m thinking of trying make something. I’m considering a foam sanding pad added to either a small drum sander or make up something from 3/4” dowel.?
Any suggestions / ideas?
-- Leon -- Houston, TX - " I create all my own designs and it looks like it "
4486 posts in 746 days
281 days ago
Leon, did you see the one from Rockler? It is 1 9/16 so it might still be too big for you.
http://www.rockler.com/product.cfm?Offerings_ID=6072&TabSelect=Details
leonmcd
281 days ago
Charlie, thanks. Seems a little big but it might work. I’ll go by and check it out tomorrow.
View tpastore's profile
tpastore
60 posts in 344 days
281 days ago
Woodcraft has some small sanding mops. Something like a smaller version of:
View Gary's profile
Gary
331 posts in 852 days
281 days ago
I haven’t used them but Abralon sanding pads have gotten good reviews elsewhere.
View Blake's profile
Blake
2206 posts in 402 days
281 days ago
I bought some of these:
From Woodcraft. Haven’t used them yet, so I couldn’t tell you how well they work. But the aren’t that expensive.
-- Check out my new website! http://www.theeasellife.com
View Alin Dobra's profile
Alin Dobra
316 posts in 416 days
281 days ago
Leon,
I would seriously consider hand sanding it. To make my life easier when I hand sand (which I do a lot by the way since it is faster sometimes than any machine sanding), I bought from Wallmart 1/8” foam pads that have adhesive on one side (they sell for about 3.50/6 sheets, you can find them in the craft area of the store). I glue a piece of sandpaper to two foam sheets and I get a flexible sanding pad. I have pads like this around all the time in grits from 60 to 1000. Alternatively you can buy sanding sponges but they are expensive.
Alin
-- -- Alin Dobra, Gainesville, Florida
View Al Killian's profile
Al Killian
203 posts in 281 days
281 days ago
I woulduse a drum to get it mostly done, then follow it up with the mop sander. This will give your box the soft round bottom.
leonmcd
276 days ago
Alin, thanks for the tip on the Wallmart foam pads. They worked great for working on my Valentine’s Box 2008 project. I only used one sheet of foam to give me the extra flexibility to get down into this small box. I like the feel of these much better than the store bought foam backed sanding pads or sanding sponges.
I also like the variety of colors so I can use a different color for each grit. Now all I have to do is remember which color is which grit.
Thanks again.
Bookmark And Share This Page
