Polyurethane signs
Forum topic by nate22 posted 06-11-2017 02:39 AM 774 views 0 times favorited 9 replies Add to Favorites Watch
View nate22's profile
nate22
475 posts in 3111 days
06-11-2017 02:39 AM
My aunt and I are making signs and my question is should I polyurethane the signs that we are making for inside? I am going to poly the ones we make for outside. And if I should what kind should I use semi gloss, or gloss or what. I use semi gloss for my furniture but will it be alright for the signs? Any opinions will help. I will post pictures when some are finished.
-- Gracie's wooden signs. Middlebury, In.
9 replies so far
View Rich's profile
Rich
3996 posts in 826 days
#1 posted 06-11-2017 03:21 AM
Not knowing exactly what the signs are made of, etc, but for something that will be indoors, pretty much any topcoat is good. If you like a satin finish, then poly or lacquer would be great.
For exterior signs, rather than plain poly, I think you’d be better off with a spar urethane. It is more flexible and UV resistant and should provide better protection against the elements, and is available in satin.
View Jim Jakosh's profile
Jim Jakosh
21956 posts in 3342 days
#2 posted 06-11-2017 11:33 AM
Hi Nate. Either won will be good inside. It depends if they look better real shiny or more matted. you and your customers will be the judge of that.. but flat, satin, semi gloss or gloss all have a place inside.
Like Rich said, for outside you need the Poly with UV resistance. Helmsman makes a good spar urethane!!
Jim
5234 posts in 2729 days
#3 posted 06-11-2017 01:49 PM
I guess I disagree with Helmsman being a good outdoor finish. Flexner once tested the UV resistance of several outdoor varnishes and concluded that because the Helmsman did so poorly, it had very little or no UV inhibitors. My suggestion would be to first of all skip anything that has urethane resin in it. They just don’t do well in the sun. That would then leave you with the true marine spars, such as Epifanes , which are extremely good. They do tend to be expensive, and need several coats. You could also consider some of the waterbornes, such as GF High Performance or Exterior 450. Lasyly, and my choice, would be paint….untinted EXTERIOR oil based paint. The mix base for dark colors (usually #4) without tint dries to look very much like oil based varnish and has a heavy dose of UV inhibitors. (more info here). Be aware, any clear coat used outdoors will need maintenance over time, so be ready to renew it one some basis.
View ArtMann's profile
ArtMann
1215 posts in 1052 days
#4 posted 06-12-2017 02:15 AM
Fred is offering good advice. I have made outdoor furniture from white oak and cypress and I have CNC routed small signs from all sorts of wood. I don’t know of a clear finish product that will hold up outside for several years. Epifanes is the best I know of. I can say that Minwax “Helmsman” so called spar varnish didn’t even hold up for one year on two cypress Adirondack chairs. They were under a porch on the North side of my house shielded from rain and direct sun. They started cracking and peeling which led to a dark mildew forming forming around the damaged finish. It is worse than worthless because it is very hard to sand that ugly mess off the original wood.
View AlaskaGuy's profile (online now)
AlaskaGuy
4987 posts in 2545 days
#5 posted 06-12-2017 03:07 AM
Go over the the professional finishing forum on the woodweb site. Do a search on Helmsman and see what pops up. It not a very good product.
http://www.woodweb.com/cgi-bin/forums/finishing.pl
Here’s a direct link to one of the threads
http://www.woodweb.com/forum_fdse_files/finishing/794882.html
Listen to Fred>
View r33tc0w's profile
r33tc0w
171 posts in 720 days
#6 posted 06-12-2017 03:28 AM
Automotive clear coat is what we use at our shop for exterior signs that are painted regardless of material. For wood, use shellac first then automotive clear
-- Matthew 13:53-58
AlaskaGuy
#7 posted 06-12-2017 04:00 AM
- r33tc0w
How much a gallon is that stuff a gallon?
View 000's profile
000
2859 posts in 1135 days
#8 posted 06-12-2017 04:01 AM
The way I see it and I mean no offense, but they’re not heirloom signs that are being made.
I wouldn’t pay more for the finish than the sign costs.
How much are you selling the average sign for?
r33tc0w
#9 posted 06-12-2017 02:16 PM
For a sign, people expect it to last at least 5 years – just go to auto zone and grab a spray can. They have UV inhibitors which help it hold up outdoors
-- Matthew 13:53-58
