Any problem with shelf pin holes going all the way through a plywood cabinet
Forum topic by MrStyle posted 06-11-2017 01:59 AM 1928 views 0 times favorited 6 replies Add to Favorites Watch
View MrStyle's profile
MrStyle
86 posts in 1847 days
06-11-2017 01:59 AM
I am in the process of making some built in cabinets and just drilled a series of shelf pin holes in the first base cabinet carcase. Unfortunately, the plywood had a bit of a void where my pin holes ended up so when I sanded – the plywood collapsed a little.
No big deal since I can flip that side so it will never be seen since it will be up against a wall.
My question is – after flipping the board to the other side and using my hole drilling jig, I ended up with the holes pins matching perfectly with the original side – so now I have two holes that go all the way through the board.
Any issue with this ? I stopped after these 2 holes – so I can recover a few different ways if need be – but anyone see any issue with having holes that line up and therefore are all the way through?
The shelves will not be supporting anything really heavy.
Thanks in advance.
View Loren's profile
10477 posts in 3764 days
#1 posted 06-11-2017 02:01 AM
I wouldn’t worry about it.
View TheFridge's profile
TheFridge
10095 posts in 1603 days
#2 posted 06-11-2017 02:07 AM
Yup
View AlaskaGuy's profile
AlaskaGuy
4354 posts in 2426 days
#3 posted 06-11-2017 02:21 AM
Redundant answer….......I wouldn’t worry about it but maybe reassuring to you. :)
View Kazooman's profile
Kazooman
1115 posts in 2069 days
#4 posted 06-11-2017 02:43 AM
No reason to worry, but if it bothers you, just plug the originals before you drill the new ones.
View MrRon's profile
MrRon
4986 posts in 3360 days
#5 posted 06-12-2017 02:06 AM
As long as the pin fits tightly in the hole; no problem. Reason: The vertical component of the load is the weight of the shelf and it’s contents divided by 4 (the number of pins). The horizontal component of the load is zero.
View ArtMann's profile
ArtMann
1043 posts in 933 days
#6 posted 06-12-2017 02:37 AM
You might take note of where you bought your plywood and avoid that source in the future. I once bought a sheet of fairly expensive Birch plywood from Lowes to construct a pair of matching painted bookcases. After ripping the pieces to width, I started to cut 1/4 inch dadoes for the shelves. The inner layers were so rotten that the material just fell apart. Nowadays, I hesitate to buy any sheet goods from a big box store, no matter what they look like.
