Cleaning cast iron
Forum topic by leftcoaster posted 06-10-2017 04:06 PM 686 views 0 times favorited 5 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
233 posts in 1117 days
06-10-2017 04:06 PM
I bought a delta drill press from a local dealer and like it a lot. Only problem is that it was evidently sitting in inventory for a while and the oiled paper that protects the cast dried on.
What’s the best way to clean this off? No I’m not going to return/exchange it.
5 replies so far
View Madmark2's profile
Madmark2
409 posts in 829 days
#1 posted 06-10-2017 04:12 PM
WD-40 & a straight razor blade.
M
woodbutcherbynight
5837 posts in 2650 days
#2 posted 06-12-2017 04:00 AM
And some elbow grease
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#3 posted 06-12-2017 06:28 AM
Give it a good wipe down with mineral spirits and let it sit for a minute or two. Make sure to saturate the paper so it gets under it. After a short while, it should just peel off without any effort. Finish wiping down with mineral spirits and a rag. Once cleaned, put on a couple coats of paste wax.
View rwe2156's profile
rwe2156
3235 posts in 1722 days
#4 posted 06-12-2017 01:49 PM
Wire wheel or flap pad on a 4” grinder.
I would soak it down with laquer thinner or acetone and try to scrape most of it off with a paint scraper.
leftcoaster
#5 posted 06-16-2017 04:29 AM
Hi all,
I followed brad’s advice about soaking and wiping with mineral spirits. Worked brilliantly. Thanks a ton!
