Finding distance between two holes
« back to Woodturning forum
Forum topic by Nubsnstubs posted 06-10-2017 12:13 AM 1198 views 0 times favorited 11 replies Add to Favorites Watch
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1969 days
06-10-2017 12:13 AM
Just a verification needed. I need to drill 2 holes to match up on my PM lathe. I can’t get up under the ways to find my centers, but can get the distance from outside to outside of each Allen bolt head. The distance is 4”, the bolt head is .550”. If I subtract the size of one bolt head from the 4”, leaving 3.45” on center, would that match up to the PM holes?........ Jerry (in Tucson)
11 replies so far
View Gene Howe's profile
Gene Howe
11157 posts in 3667 days
#1 posted 06-10-2017 12:49 AM
Seems right.
View 000's profile
000
2859 posts in 1138 days
#2 posted 06-10-2017 12:58 AM
That would be center to center measurement.
View REO's profile
REO
929 posts in 2313 days
#3 posted 06-10-2017 01:18 AM
Yup you got it jerry!
Nubsnstubs
#4 posted 06-10-2017 02:51 AM
Thanks, guys, I thought that was it, but old age, ya know…... Now I’ll proceed and get some stuff set up for my lathe. .......... Jerry (in Tucson)
View hotbyte's profile
hotbyte
991 posts in 3214 days
#5 posted 06-10-2017 11:58 AM
You could also measure from outside of one to inside of the second which is equivalent to subtracting the diameter. The advantage being you don’t need to know bold diameter.
Nubsnstubs
#6 posted 06-10-2017 01:59 PM
You could also measure from outside of one to inside of the second which is equivalent to subtracting the diameter. The advantage being you don t need to know bold diameter.
- hotbyte
If my poor old legs, tired old body, and real old eyes would have let me me do it that way, that would have been my preferred method.There wasn’t really enough room for the calipers with out interference from the lathe body, so I took the easiest measurement and figured I could do the math. Then senior moment stepped in, and cause me to have second thoughts about what I just did….
When looking for hole centers, 99% of the time it’s done the way you mentioned
Better yet, if Powermatic would have heeded my suggestion of putting all leg mounting holes on the outside instead of up and under the ways, I wouldn’t have had a need to ask this question. :O).......... Jerry (in Tucson)
View MrRon's profile
MrRon
5270 posts in 3482 days
#7 posted 08-02-2017 05:13 PM
You will get close, but not exactly. There is a clearance around each bolt, so the center of the bolt is not necessarily the center of the hole.
View Woodknack's profile
Woodknack
12465 posts in 2619 days
#8 posted 08-02-2017 06:48 PM
Like hotbyte I measure from left side to left side, or outside to inside, however you want to say it. But whatever works, works.
View Jack Lewis's profile
Jack Lewis
369 posts in 1317 days
#9 posted 08-06-2017 09:13 PM
Jerry; Just buy another lathe and measure before you put it together. Rick M. has the idea on the nose!
-- "PLUMBER'S BUTT! Get over it, everybody has one"
Nubsnstubs
#10 posted 08-07-2017 03:46 PM
- Jack Lewis
Jack, I can’t even afford to pay attention. How do you expect me to buy another lathe?
I already did what I had to. I have been using Ricks and hotbytes method for at least the last 20 years, or maybe longer. Just about 3 months ago when I wanted to drill the holes, I had a mental fart, and couldn’t remember how. That’s why I posted this question, just to verify. At almost 71 years old, things are starting to take a little longer to remember. Just like an old computer, I’m getting slow.
- MrRon
I’m gonna disagree Ron. If both holes are the same size, center is center. The only time the bolts won’t be in the center is if the holes are oversized, and you just screw the bolts in or the holes were drilled different than the mating holes. ........... Jerry (in Tucson)
View Dark_Lightning's profile
Dark_Lightning
3367 posts in 3348 days
#11 posted 08-08-2017 03:08 AM
- Jack Lewis
Jack, I can t even afford to pay attention. How do you expect me to buy another lathe?
I already did what I had to. I have been using Ricks and hotbytes method for at least the last 20 years, or maybe longer. Just about 3 months ago when I wanted to drill the holes, I had a mental fart, and couldn t remember how. That s why I posted this question, just to verify. At almost 71 years old, things are starting to take a little longer to remember. Just like an old computer, I m getting slow.
- MrRon
I m gonna disagree Ron. If both holes are the same size, center is center. The only time the bolts won t be in the center is if the holes are oversized, and you just screw the bolts in or the holes were drilled different than the mating holes. ........... Jerry (in Tucson)
- Nubsnstubs
Whenever a hole is drilled for a fastener, it is drilled at some size larger than the fastener in order to accommodate the variation in the articles held together, and in the diameter of the fasteners. This is a standard mechanical engineering practice.
-- Random Orbital Nailer
