Cart for Benchtop Tools
Forum topic by EdsCustomWoodCrafts posted 06-09-2017 04:47 PM 923 views 0 times favorited 11 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
782 posts in 1368 days
06-09-2017 04:47 PM
Hi Guys,
I am in the designing phase of building a workshop cart on wheels that I can store my benchtop drill press, band sad and if possible store my spindle sander and air compressor ..
Any ideas!! I think I have just enough room for 36-40” width
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
11 replies so far
View Woodknack's profile
Woodknack
11785 posts in 2405 days
#1 posted 06-09-2017 04:53 PM
View AngieO's profile
AngieO
1267 posts in 2173 days
#2 posted 06-09-2017 04:59 PM
I really like that too Rick.
I like this one
http://lumberjocks.com/replies/1392242
- Rick M
AngieO
#3 posted 06-09-2017 05:08 PM
I just built this miter station recently. Right now I store my shopvac under it on one side and on the other I have a rolling microwave cart that fits perfectly under it as well as my little bucket vac that hooks up to my Kreg jig and biscuit jointer. That cart hold my sanders, my dremel and my corded circular saw. My air compressor sits under the miter saw as well as a few other things I rarely use. This is not complete though. I used plans from Ana White to build this. And I intend to add the two carts from the plan that will tuck under each wing. I also would like to enclose the air compressor.
This guy is massive. It’s huge. Although it’s a bit high.. I chose not to alter the height and it’s working perfectly for me. I do plan on altering the two carts from their design but mostly they will follow the same concept.
EdsCustomWoodCrafts
#4 posted 06-09-2017 06:23 PM
Although these are nice they are not what I had in mind .. Ineed it on wheels and I have enough space to fit 40” wide
View jerryminer's profile
jerryminer
928 posts in 1467 days
#5 posted 06-09-2017 06:43 PM
I like this one, too—- especially that router table accessory peeking over the fence!
I like this one
- Rick M
Woodknack
#6 posted 06-09-2017 07:15 PM
- edwood1975
Yeah I didn’t know of one with the combination you want so I posted the closest thing thinking you might get some ideas. Are you wanting something like a double flip cart? A cart that stores machines is not much to go on.
View sras's profile
sras
4811 posts in 3154 days
#7 posted 06-09-2017 11:59 PM
This issue of Woodsmith has a concept that might be closer. I like their idea, but their box/drawers are a little to complicated for my taste.
Woodknack
#8 posted 06-10-2017 02:22 AM
They are mimicking Systainers.
EdsCustomWoodCrafts
#9 posted 06-10-2017 02:38 AM
They totally mimicking sustainers … I’m just going to have to hit Sketchup and get the restive juices flowing… I need a work surface as well as storage .. I think a box with internal shelf system probably on pin hole supports …
I’ll post the project after completion
View canadianchips's profile
canadianchips
2602 posts in 3022 days
#10 posted 06-10-2017 04:03 AM
I built these for my trailer. I can roll them in and out easily….One holds welder, air compressor.
Other one has vacuum, two routers in table top , third one is drawers for hand tools. These are the sketch designs, my pictures of them are gone !....One day will have to take more pics.
View hairy's profile
hairy
2718 posts in 3557 days
#11 posted 06-10-2017 12:37 PM
I start my carts looking like this.
It became a lumber cart.
I could put a top on to be a work table, or mount power tools, or put shelves in it. The framework is glued and screwed together, but a top or shelves would be screwed only. Remove the screws when you need it to be something else.
It’s basically tongue and groove, I use a dado blade on the TS.
-- My reality check bounced...
