How deep should router bit be in the collet?
Forum topic by Carloz posted 06-09-2017 02:57 PM 945 views 0 times favorited 10 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 498 days
06-09-2017 02:57 PM
There is a lot of information that router bit should be inserted almost as deep as it goes minus some small gap 1/16” or so. However if I do that with my Bosch router the carbide flutes sit deep in the collet. I have to pull it out more than half inch just to clear the carbide. Then I start wondering how safe it is to keep it that shallow. Any thiughts, i use whiteside and freud bits.
10 replies so far
View sras's profile
sras
4749 posts in 3036 days
#1 posted 06-09-2017 03:09 PM
If you look at your collet, you can see the jaws that do the actual clamping. As long as the bit is fully engaged in those jaws the bit is deep enough – at least for the consideration of the collet clamping the bit.
Whenever possible, the guideline you shared is preferred. You want the forces of cutting as close to the collet as possible.
View WhyMe's profile
WhyMe
981 posts in 1468 days
#2 posted 06-09-2017 03:10 PM
You should at least push the bit shank in far enough to fully engage the clamping surface of the collet jaws.
4882 posts in 2400 days
#3 posted 06-09-2017 03:11 PM
Seems like I remember Charles (from Freud) saying that at least 2/3s of the shank should be in the collet. If that’s not right someone will remember. I do know you don’t set the flutes into the collet, and I’ve never heard a recommendation to seat it as deep as possible. On my Milwaukee routers the hole is deeper than some of the bits are long.
View Ripper70's profile
Ripper70
800 posts in 815 days
#4 posted 06-09-2017 03:13 PM
How to Install a Router Bit
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View hairy's profile
hairy
2607 posts in 3439 days
#5 posted 06-09-2017 03:18 PM
I always put it in all the way, then bring it out 1/16” or so.
-- My reality check bounced...
View Madmark2's profile
Madmark2
379 posts in 495 days
#6 posted 06-09-2017 03:47 PM
I put O-rings on the shaft just below the start of the curve under the cutter. Makes it easy to set the bit and acts as a 3rd hand so the bit doesn’t slip while tightening.
M
View BigYin's profile
BigYin
406 posts in 2323 days
#7 posted 06-09-2017 04:02 PM
View knotscott's profile
knotscott
7875 posts in 3282 days
#8 posted 06-09-2017 04:16 PM
Here’s one visual aid from Tork Craft:
View Markmh1's profile
Markmh1
67 posts in 350 days
#9 posted 06-09-2017 07:02 PM
If you use Zip-Strip or some other degreaser on your collet and router shank, get everything absolutely clean and dry, you’ll minimize the chances of the cutter pulling out during operation.
Another simple trick is to put marker around the collet/shank junction to watch for cutter movement. It’s easy to see the white metal above the marker if the cutter starts to pull out. The idea here is to minimize the damage of movement.
Mark
View JBrow's profile
JBrow
1327 posts in 827 days
#10 posted 06-10-2017 02:24 AM
Carloz,
The 8th bullet under the heading “General Guidelines, Tips, and Safety” on page 3 of the MLCS Technical Manual advises that at least ¾” of the router bit shank should be installed in the collet.
BigYin mentioned a router collet extension. On page 23, MLCS technical Manual also discusses the router collet extension and it use
https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/graphics2/Technical_Manual.pdf
