Tools Explained. Got any others to add?
Forum topic by Viking posted 905 days ago 1089 views 2 times favorited 21 replies Add to Favorites Watch
View Viking's profile
Viking
858 posts in 1368 days
905 days ago
Topic tags/keywords: humor
TOOLS EXPLAINED
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, “Oh, shit!”
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle… It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use..
Son of a bitch TOOL:
Any handy tool that you grab and throw across the garage while yelling “Son of a bitch” at the top of your lungs. It is also, most often, the next tool that you will need.
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
21 replies so far
View DragonLady's profile
DragonLady
298 posts in 1179 days
#1 posted 905 days ago
omg, this had me laughing so hard my boyfriend had to come see :P
now he won’t let me back into my shop!!
-- A woman's work is never done-but power tools help!
View canadianchips's profile
canadianchips
1775 posts in 1169 days
#2 posted 905 days ago
STICK WELDER: Is a nice tool to give yourself SHOCK therapy treatments while changing electrodes with a sweaty glove.
PORTABLE HAND GRINDER: Very useful to burn off your shoelaces with from the sparks.
PNEUMATIC NAIL GUNS: With this tool you have the ablity to inflict pain upon YOURSELF with just touch of a trigger. Nail coming out side of board instead of going IN.
NAIL PULLER: (Sliding action model) Everyone has made a blood blister between thumb and pointer finger with one of these.
View Don's profile
Don
504 posts in 1245 days
#3 posted 905 days ago
CHISEL:
A metal tool with a sharp beveled edge. Useful for scraping glue, lacerating a finger, and embedding glue into laceration in one quick action.
-- Don - I wood work if I could. Redmond WA.
canadianchips
#4 posted 905 days ago
CARPENTER PENCIL:
An evasive marking device that has the ability to sit somwhere for days without being detected. When you need it, it has the ability to become invisible. When we do find it, the lead is broken OFF eveytime.
View helluvawreck's profile
helluvawreck
10500 posts in 1039 days
#5 posted 905 days ago
BUILDING STRETCHER:
The tool that you send the nearest dumb ass to the hardware store to get for you when you want to get rid of him for an hour or so.
helluvawreck
#6 posted 905 days ago
DUCK TAPE:
What you cover the dumb ass’ mouth with if he comes back from the hardware store too quickly after he doesn’t find the BUILDING STRETCHER.
View GregD's profile
GregD
597 posts in 1308 days
#7 posted 905 days ago
I must have the delux VISE GRIPS – mine break off the bolt head once it is properly rounded. Works the same for screws that strip out before I get them screwed in all the way.
-- Greg D. -- the price of freedom is tolerance
View DaddyZ's profile
DaddyZ
2008 posts in 1213 days
#8 posted 905 days ago
CHEAP CLAMPS:
Use to glue projects together at odd angles because you went to get another beer & the thing broke.
GOOD CLAMPS:
Use to glue clamp pads to wood so you can’t remove clamp.
View TheDane's profile
TheDane
2678 posts in 1835 days
#9 posted 905 days ago
REFRIGERATOR:
Shop fuel storage device.
BEER:
Shop fuel (see REFRIGERATOR)
BOARD EXTENDER:
Most elusive tool in the shop. Needed only by those of us who only measure once before cutting or those who have embibed mass quantities of Shop Fuel (see: REFRIGERATOR and BEER).
May also be used as a substitute for the BUILDING STRETCHER (detailed above).
helluvawreck
#10 posted 905 days ago
I plum forgot about the refrigerator and the beer, Dane. They are essential tools. Good thinkin. :) What was it that Degoose called the refrigerator?
View sawblade1's profile
sawblade1
750 posts in 1199 days
#11 posted 905 days ago
Tape measure
The only tool that can give you two measurements and never be right either way and the only tool that likes to mysteriously lurk under your miter saw blade only to be found chopped in half after you’ve made your cut
-- Proverbs Ch:3 vs 5,6,7 Trust in the lord with all thine heart and lean not unto your own understanding but in all your ways aknowledge him and he shall direct your path elmerthomas81@neo.rr.com
View chrisstef's profile
chrisstef
5310 posts in 1179 days
#12 posted 905 days ago
BUCKET OF STEAM:
See building extender
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View Gregn's profile
Gregn
1643 posts in 1156 days
#13 posted 904 days ago
Computer:
Device used to take place of your memory bank because you suffer from CRS, and to communicate with other LJ’s to bail you out of a jam.
Viking
#14 posted 904 days ago
Just like clamps …. you can never have enough tools explained!
These are GREAT!
View fredf's profile
fredf
495 posts in 1882 days
#15 posted 904 days ago
“NAIL PULLER: (Sliding action model) Everyone has made a blood blister between thumb and pointer finger with one of these.”
brings back memories . . I did about 50 years ago as a kid!!
-- Fred, Springfield, Ma
