What kind of saw blade is this?
Forum topic by Woodknack posted 06-09-2017 05:45 AM 1452 views 0 times favorited 11 replies Add to Favorites Watch
View Woodknack's profile
Woodknack
12329 posts in 2496 days
06-09-2017 05:45 AM
5/8” arbor
about 6-1/4” diameter
very aggressive teeth
no markings
I found it in a stack of blades given to me several years ago.
11 replies so far
View AlaskaGuy's profile
AlaskaGuy
4353 posts in 2425 days
#1 posted 06-09-2017 05:59 AM
It looks to me like an old rusty blade.
The diamond knock out looks like it’s a blade for a circular saw to me.
https://youtu.be/nZGlWCdleTc
Look at the arbor on this saw
https://youtu.be/qNOURvOPG28
Woodknack
#2 posted 06-09-2017 06:39 AM
You’ve narrowed it down to a rusty circular saw blade, clearly at the top of your game! I hope you didn’t need youtube to figure it out. :)
In all seriousness though, I don’t care about the knock out. I take it that you believe this is a regular wood cutting blade. The teeth on this are larger than a normal blade this size with a very forward rake. It would be quite aggressive if used on wood. I was wondering if it was for some other material.
View Dutchy's profile
Dutchy
3064 posts in 2284 days
#3 posted 06-09-2017 06:51 AM
This is a CV (ChroomVanadium) blade for wood used before TC tipped sawblades where on te market or to expensive. Also sawmills have used this type of sawblad despite that for a long time TC sawblades where on the market. This for the iron in the wood. And also hobyists have used CV sawblades for a long time after TC was intoduced simply because a TC blade was te expensive. CV blades are easy to sharpen. The aggrisive teeth where commen for this type of sawblade. If you make a TC sawblade with the same geometry the tooth will be damaged very quickly. Jigsaws, wood chisels and so on are still often equipped with CV tools/steel.
-- https://dutchypatterns.com/
AlaskaGuy
#4 posted 06-09-2017 07:10 AM
You ve narrowed it down to a rusty circular saw blade, clearly at the top of your game! I hope you didn t need youtube to figure it out. :)
In all seriousness though, I don t care about the knock out. I take it that you believe this is a regular wood cutting blade. The teeth on this are larger than a normal blade this size with a very forward rake. It would be quite aggressive if used on wood. I was wondering if it was for some other material.
- Rick M
“What kind of saw blade is this?” I thought that was a pretty broad bush. I didn’t know just what you were after.
Dutchy gave you an excellent answer it would seem. Much better than I could have even if I had known what you were after.
View knotscott's profile
knotscott
8120 posts in 3491 days
#5 posted 06-09-2017 09:35 AM
I’d call that a clock! :-)
View HorizontalMike's profile
HorizontalMike
7770 posts in 3030 days
#6 posted 06-09-2017 10:08 AM
I d call that a clock! :-)
- knotscott
Way to put a “spin” on this… ;-)
View Jim Jakosh's profile
Jim Jakosh
21105 posts in 3221 days
#7 posted 06-09-2017 11:52 AM
I’d use it for a rip blade on my skill saw. I can resharpen it quickly and re-set the teeth with a hammer over a block of steel. I still have a few laying around but pitched most of them now that I use a lot of carbide blades and they are pretty cheap…. but the cheap carbide blades are throw aways and this one i can resharpen.
Jim
View HokieKen's profile
HokieKen
6153 posts in 1254 days
#8 posted 06-09-2017 12:00 PM
Looks like the blades I used to see when I was a kid in my Dad’s circular saw he used on job sites. If I had to guess I’d say it was for cutting construction lumber that couldn’t be cut in a single pass. Those big gullets would be needed in a blind cut.
-- Kenny, SW VA, Go Hokies!!!
View jbay's profile
jbay
2583 posts in 1015 days
#9 posted 06-09-2017 01:49 PM
It’s definitely high quality no matter what.
A cheap blade would not have had a hole to hang it from. :)
View mahdee's profile
mahdee
3970 posts in 1883 days
#10 posted 06-09-2017 03:49 PM
I have a RAS and the blade looks a lot like that. Probably from that era.
-- earthartandfoods.com
Woodknack
#11 posted 06-09-2017 04:19 PM
- knotscott
Best Answer!
Or future marking knife
I d use it for a rip blade on my skill saw.
- Jim Jakosh
I have never seen such an aggressive tooth in a blade this small but I searched again today, adding “vintage” to the search string and found one. Jim is right, it is a rip blade.
It s definitely high quality no matter what.
- jbay
For your convenience, lol.
