Handrail. Durable finish. Oil Based Polyurethane?
Forum topic by Fax posted 06-08-2017 04:00 PM 904 views 0 times favorited 10 replies Add to Favorites Watch
View Fax's profile
Fax
62 posts in 574 days
06-08-2017 04:00 PM
Topic tags/keywords: question oak finishing
Hello friends.
Would oil based polyurethane be a good durable finish for handrail ?
I have a can of ZAR Oil Polyurethane
Thank you very much for your help !
Julian
-- Julian Paul Jones
10 replies so far
View jdh122's profile
jdh122
1034 posts in 2935 days
#1 posted 06-08-2017 04:08 PM
Yes, as long as it’s inside.
-- Jeremy, in the Acadian forests
View Fax's profile
Fax
#2 posted 06-08-2017 04:50 PM
Yes, as long as it s inside.
- jdh122
Hi Jeremy
Thank you very much for your help!
View EarlS's profile
EarlS
1523 posts in 2465 days
#3 posted 06-08-2017 05:08 PM
I used poly urethane on my handrails. Apply several thin coats and lightly sand between coats and you will have a finish that should last for a very long time.
View Fax's profile
Fax
#4 posted 06-08-2017 05:21 PM
- EarlS
Hi Earl,
I will definitely go for the Oil Based Polyurethane then.
This is so helpful because someone said not to use polyurethane on handrail because the oils from the hands will gum up the finish.
I wonder if that is the problem with Water Based Polyurethane on handrails. I don’t know .
EarlS
#5 posted 06-08-2017 05:27 PM
Oil or water based poly should work. Make sure to let things dry before applying the next coat. Too many times bad finishes can be traced back to being impatient and not waiting for things to dry. Other culprits include not putting on enough coats or thinking that a couple of thick coats is the same as several thinner coats.
I’m guilty as charged with impatience, especially with Watco Danish oil. Having to sand the project back to bare wood and start over is punishment enough to remember that waiting is still faster than re-finishing.
Thick coats wind up with runs, drips, and sags, all of which mean you get to sand off the finish and start over as well.
Not enough coats means the wood isn’t fully sealed and protected so oil or water can get under the finish and cause problems like tackiness.
View papadan's profile
papadan
3584 posts in 3486 days
#6 posted 06-08-2017 05:35 PM
I have to recommend a water based poly, at least for the final coats. Warmer weather and oils from hands will affect an oil finish over time. Water based for all of it if you want crystal clear finish, oil based will darken the wood some and pop any grain in the wood. If you use the oil based just follow with the last 2 coats in water based for a clean hard finish that will hold up to anything.
View Fax's profile
Fax
#7 posted 06-08-2017 05:35 PM
I m guilty as charged with impatience, especially with Watco Danish oil. Having to sand the project back to bare wood and start over is punishment enough to remember that waiting is still faster than re-finishing.
Not enough coats means the wood isn t fully sealed and protected so oil or water can get under the finish and cause problems like tackiness.
- EarlS
Thank you very much Earl !
This so good to know.
I am very grateful for this.
View Fax's profile
Fax
#8 posted 06-08-2017 05:41 PM
- papadan
Hi
Thank you very much!
Wow, so the water based polyurethane on handrail is a very durable finish.
I had bo idea what to use.
I am very grateful for your help!
View Jeff's profile
Jeff
467 posts in 3312 days
#9 posted 06-08-2017 06:03 PM
About 10 years ago I redid our stairs (treads, risers and all railings) in red oak. I used Minwax stain then two coats of water based polyurethane in satin finish. Though two kids and many sweaty summers it’s held up.
View Fax's profile
Fax
#10 posted 06-08-2017 06:18 PM
About 10 years ago I redid our stairs (treads, risers and all railings) in red oak. I used Minwax stain then two coats of water based polyurethane in satin finish. Though two kids and many sweaty summers it s held up.
- Jeff in Huntersville
Hi Jeff,
I am so glad to hear all these things.
In the past I regretted it big time for not asking experienced people about wood finishing.
I am definitely gonna do the water based polyurethane especially for the fact that they dry fast and don’t smell bad.
Thank you so much!
Julian
