Not enough sleeves for spindle sander
Forum topic by logwolf posted 06-08-2017 01:42 AM 1497 views 0 times favorited 11 replies Add to Favorites Watch
View logwolf's profile
logwolf
32 posts in 646 days
06-08-2017 01:42 AM
Topic tags/keywords: spindle sanders self adhesive sandpaper
My friend, who is a wood worker, does a lot of pro bono work for the local “Gun & Rod Club”.
He needs to borrow my Wen oscillating spindle sander and will be using the 1 1/2” or 2” diameter spindles on a project which involves sanding 70 openings with the spindle sander.
No one sells a pack of 10 or 20 1 1/2” or 2” sanding sleeves. So I was wondering if a roll of self adhesive sanding paper, cut to length to make numerous quantities of the 1 1/2” or 2” would work?
Has anyone had experience with self adhesive rolls, and used them on the spindles. Would they be too sticky and difficult to remove from the rubber spindle sleeves?
Any feed back would be grateful. Thanks
-- Larry
11 replies so far
View sras's profile
sras
4866 posts in 3244 days
#1 posted 06-08-2017 01:48 AM
I see that Industrial Abrasives sells their sleeves in 6 packs. Not sure how good their price is though…
View HokieKen's profile
HokieKen
6146 posts in 1253 days
#2 posted 06-08-2017 02:03 AM
I don’t think it would work very well because of the seam. Why do you need so many? What grade paper? What kind of wood? I would think you could do 10 parts per sleeve at least.
-- Kenny, SW VA, Go Hokies!!!
View HerbC's profile
HerbC
1785 posts in 2974 days
#3 posted 06-08-2017 03:25 AM
Klingspor sells 5 packs for less than $6.00. I’ve had good experience with their products. Here’s the page listing 2” X 3” sleeves: Here
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Redoak49's profile
Redoak49
3449 posts in 2103 days
#4 posted 06-08-2017 10:55 AM
Klingspor is my source for sleeves
View HorizontalMike's profile
HorizontalMike
7770 posts in 3028 days
#5 posted 06-08-2017 01:15 PM
Try Grizzly. They have several sizes/grits available.
http://www.grizzly.com/search?q=(sanding+AND+sleeves)+OR+(sanding+OR+sleeves)
View GR8HUNTER's profile
GR8HUNTER
4528 posts in 827 days
#6 posted 06-08-2017 01:30 PM
- logwolf
WHY do you need so many 10 for 70 holes ???? :<))
logwolf
#7 posted 06-08-2017 09:56 PM
Klingspor sells 5 packs for less than $6.00. I ve had good experience with their products. Here s the page listing 2” X 3” sleeves: Here
Good Luck!
Be Careful!
Herb
- HerbC
Thanks Herb
I’ll check out their site….AND, Thank you, ...I will be careful. Sorry to hear of your accident.
Larry
-- Larry
logwolf
#8 posted 06-08-2017 09:59 PM
Thank you everyone for your feedback. Greatly appreciate it.
GR8Hunter…I’d rather my friend have more than he needs. And since he’s the one doing the work, I know he puts a lot of hard physical pressure on his tools.
-- Larry
HorizontalMike
#9 posted 06-09-2017 10:14 AM
- HorizontalMike
Sorry, broken link. LJs keeps cutting off the last parentheses. Add the “)” after you click on the link and it will get you to the right location.
View xeddog's profile
xeddog
199 posts in 3122 days
#10 posted 06-09-2017 03:26 PM
I don’t have the Wen spindle sander, but a Delta. You do know, don’t you, that you can turn the sleeves upside down and use the other end of them too? That way you can get two holes per sleeve.
Wayne
logwolf
#11 posted 06-09-2017 06:41 PM
Xeddog, thank you I was aware of doing that, but again, I’m not the one doing the work. My friend has a tendency to push hard when running tools. I’m also not sure how thick the wood is that he’s using because it’s for a Gun Rack. Thank you again.
-- Larry
