glue or float the drawers
Forum topic by Paul posted 12-01-2010 12:16 AM 1874 views 0 times favorited 9 replies Add to Favorites Watch
View Paul's profile
Paul
224 posts in 3446 days
12-01-2010 12:16 AM
Topic tags/keywords: drawer glue
Just made 6 drawers for the garage cabinetry and will be gluing them later tonight.
The draws are all 22 inches deep and range from 25 to 34 inches in width. I am using 1/2 birch ply for bottoms which are dadoed into 3/4 poplar sides. which are dovetailed.
My question is do I need to glue the bottoms in for added strength or will this come back to bite me due to movement.
How much movement will I encounter with the plywood? or is it the sides that will need to move?
I will spray poly urethane if that will help deter movement.
Thanks in advance
Paul
9 replies so far
View Gene Howe's profile
Gene Howe
10477 posts in 3422 days
#1 posted 12-01-2010 12:33 AM
The only part that will move will be the sides. They will move across the grain. Assuming your grain runs horizontally, you might get a pinched drawer bottom. Other than that, I can’t see a problem with gluing in the bottoms. Although, those drawers are going to be pretty darned strong without gluing the bottom. If it were me, I’d just slide ‘em in and nail ‘em off.
View Paul2274's profile
Paul2274
330 posts in 3106 days
#2 posted 12-01-2010 01:02 AM
I’ve always just slid in the bottoms and placed a single tack nail in the center of the back to hold. No real need to glue.
Paul
View TheDane's profile
TheDane
5423 posts in 3657 days
#3 posted 12-01-2010 01:08 AM
+1 for what Gene and Paul said.
View Paul's profile
Paul
#4 posted 12-01-2010 01:26 AM
I was thinking that since the drawers are for the garage and they might be loaded heavy at times ( wrenches and ratchets) that the glue to the bottom will add strength and will less likely to allow all the sides to twist over time.
Thanks again.
View juniorjock's profile
juniorjock
1930 posts in 3759 days
#5 posted 12-01-2010 01:30 AM
I may be wrong, but I don’t think you’ll get that much movement with plywood.
- JJ
View Sawkerf's profile
Sawkerf
1730 posts in 3062 days
#6 posted 12-01-2010 01:33 AM
I never glue drawer bottoms – they ride in dados on three sides and get tacked in the back. I’ve made hundreds of drawers and some of them have carried pretty heavy loads. None have failed (that I know of.)
juniorjock
#7 posted 12-01-2010 01:55 AM
I agree with Sawkerf. Just do it.
- JJ
View TheWoodsman's profile
TheWoodsman
65 posts in 2890 days
#8 posted 12-01-2010 05:13 AM
Plywood bottom is safe to glue. The extra rigidity offered by the glued bottom will help ensure that the drawer stays strong and solid over the long term. DO IT !
-- I'm the Woodsman . . . the four-wheelin', tree-farmin', custom-furniture-makin' descendant of Olaf "The Woodcutter" Ingjaldsson.
View grizzman's profile
grizzman
7836 posts in 3297 days
#9 posted 12-01-2010 05:54 AM
i would not glue them…they dont need it and if for some reason you need to replace them..you wont be able to…i dont have a dato in the rear of mine…i leave it straight cut so that the drawer bottom just slides in over it…nail in a few tacks and then if need be you can pull them and the bottom slides right out…if it were to get stained you can just turn it over and reuse it…or if its damaged…you can easily replace it…but if you glue…the drawer is not fixable..
-- GRIZZMAN ...[''''']
