Looking for help designing Racing simulator !!!
Forum topic by magnus posted 11-30-2010 09:00 PM 1130 views 0 times favorited 4 replies Add to Favorites Watch
View magnus's profile
magnus
10 posts in 3167 days
11-30-2010 09:00 PM
Hello Folks!
I haven’t posted in here in a while, but I have an upcoming project that I need help with.
The Wife asked what I wanted for Xmas, and I showed her this.
http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=3855376
In case the link doesn’t work – it’s a racing wheel and petals for PS3 or PC games.
What I thought would be really cool would be to build an enclosure and permanently mount the wheel and petals to some good ‘ol lumber! I’m looking for a design idea to build a relatively inexpensive enclosure to simulate the inside of a racing car. I am going to look for an old seat out of a sports car and mount that in there, but if that fails, I will just modify an office chair and put that in. The only dimension I could find on the wheel was that it had a 11” diameter. I guess you could ballpark the rest from that stat.
My idea is to have a 4 sided enclosure, with the bottom opened, as well as left side that would be pushed up against a wall.
the enclosure would be roughly square in shape with an LCD televison (32”) as the front windshield, and the ride side of the box would be roughly shaped like a car door, and actually be able to open up like a car door.
I would make the exterior out of cheap plywood, maybe 1/8” or 1/16” thickness, but maybe would like to sand and paint it as well. The “dashboard” would be maybe 2×6”, and the petals would be hard mounted to the bottom front on the inside (like a normal car).
i’m 5’10” tall, and I want just enough room to open the door and sit down.
If anyone has a design suggestion I would love to see it.
take care,
Mark
18615 posts in 4126 days
#1 posted 12-01-2010 12:47 AM
I might have seem something similar on here sometime ago.. maybe a year or two .. not sure what to do a search for though..
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3080 days
#2 posted 12-01-2010 01:09 AM
I think the nam was Gameconsol or the ultimativegameconsol or something simular
ultimative arcadeconsol, try to play with the words around the tipical words used to such things
Dennis
View Dan Lyke's profile
Dan Lyke
1519 posts in 4090 days
#3 posted 12-01-2010 03:52 AM
So plywood thickness wise, I think you mean 3/8” or 1/2”. With anything thinner, ie ¼”, I’ve found I need to either support the wood fairly well (ie: as a cabinet back), or curve it.
Design-wise, I’d build it around the seat. And build the parts to which the controls are attached a little beefy. I did simple controls for a helicopter simulator, and controlling a helicopter simulator requires a delicate touch, but people still managed to bend the ¼ threaded rod I used for my pedal hinges. If I did it again today I’d make sure that was supported on both sides.
magnus
#4 posted 12-01-2010 04:25 AM
thx for the replies… maybe 1/4” is what i meant.
I guess what i’m looking for is ideas on what joints to use, what thickness is sturdy enough, etc.
i’ll work on the design a little tomorrow and see if I can upload a drawing.
