Powermatic 68 ..Looking for a pulley
Forum topic by jbay posted 06-07-2017 02:53 AM 1325 views 0 times favorited 14 replies Add to Favorites Watch
View jbay's profile (online now)
jbay
2581 posts in 1014 days
06-07-2017 02:53 AM
Does anybody know of a good source where I can get a 3 belt/groove pulley that goes onto the motor?
Someone put a 2 belt pulley on it and I would like to correct it.
Thanks in Advance for any help.
14 replies so far
View AlaskaGuy's profile
AlaskaGuy
4353 posts in 2424 days
#1 posted 06-07-2017 07:34 AM
A quick Google search to all the usual place come up as discontinued. Apparently the part# is 3717060. It’s a 7/8 bore.
I have an old Delta Rockwell 12-14 saw with a 3 grove pulley. Several years back I broke one of the belts. Never got around to replacing it. Honestly I can tell the difference in performance.
Personally I would mess with it if it’s a big hassle. Maybe a bearing/transmission shop could help.
jbay
#2 posted 06-07-2017 01:42 PM
Thanks
The pulley on it now has wider grooves than the arbor pulley, and is offset about 1/2”
Right now the pulley is flush with the shaft. To align the belts I would have to hang the pulley off of the shaft that 1/2” which I could, but don’t really want to. That will be plan B if I can’t find an aftermarket pulley to work.
I appreciate you taking the time to look that up for me.
jbay
#3 posted 06-07-2017 03:30 PM
Just got the motor out. Visual measurement of the shaft.
I’m thinking someone must have changed out the motor some time down the line.
I thought these came with 5hp motors?
runswithscissors
2818 posts in 2140 days
#4 posted 06-09-2017 04:14 AM
Applied Technologies has gobs of pulleys. Google them.
jbay
#5 posted 06-09-2017 01:29 PM
Thanks,
I googled them.
So far the only pulley’s I have been able to find are the type that require a bushing.
Any of the other fixed bore pulley’s (11/16 – 3/4” bore) only go up to 2 grooves.
Thanks for the site.
View magaoitin's profile
magaoitin
247 posts in 1064 days
#6 posted 06-09-2017 05:58 PM
Tricky…
I know it is probably a silly question, but have you tried searching Marathon's website for an authorized service shop near you? They could decode the model number and probably know where to find the pulley that fits that shaft.(heck they probably even have one on the self)
There are 2 commercial electric motor repair shops by me (Tacoma Washington) that have been an amazing resource for my “vintage” Powermatic 60. I have the original 1952 motor in mine and it has a 3/4” shaft like yours. (Mine is a 2 belt.)
First is Center Electric and the other is Electric Motors Service and Controls. Center Electric is a Marathon repair shop too.
You probably have a local electric motor repair place that does commercial rebuilds on small motors and skip the shipping, but its worth a phone call.
I don’t see a frame number on that badge, just the model number. I am going out on a limb and would say it is older than 1952? That might be the tough part for finding the part you need. A marathon motor repair shop would need to search that motor’s model number to match up the pully…if one exists. Since it is not the original motor, and it looks fairly old it might not be made anymore.
-- Jeff ~ Tacoma Wa.
jbay
#7 posted 06-09-2017 06:09 PM
Thanks Jeff,
I’ll check them out. There is one service center on Marathon’s list that I may try.
I appreciate your time.
View MrUnix's profile
MrUnix
6882 posts in 2314 days
#8 posted 06-09-2017 06:50 PM
What is the O.D. of the pulley? It obviously isn’t the original motor, which had a 7/8” shaft, so the PM replacement won’t be applicable – and being specific to the PM, I seriously doubt Marathon would have anything applicable. There are a few places you can find multi-belt sheaves with a 3/4” finished bore though, such as motion industries. – But you will need to find a matching one with the same O.D. or the speed at the arbor will change.
In reality, two belts are fine. If it’s working well as it is, I’d just leave it alone and make sawdust.
jbay
#9 posted 06-09-2017 07:04 PM
The OD of the existing pulley is 3”, same as the arbor pulley.
I’m going to check a few more places first but if nothing comes up I will start making sawdust.
Thanks
AlaskaGuy
#10 posted 06-09-2017 07:44 PM
In my first post I said “Honestly I can tell the difference in performance.” That should have said ” “Honestly I can’t tell the difference in performance.”
MrUnix
#11 posted 06-09-2017 08:30 PM
- jbay
That doesn’t sound right and apparently a PO just slapped on whatever they could find. The original pulley (P/N 3717060 – same as used on the PM66 IIRC) should be 3.4” in diameter. With a 3” pulley on both the motor and the arbor, the 1:1 ratio makes the blade spin at motor speed (3450 rpm). The arbor should be spinning closer to 4000 rpm. With a 3.4” motor pulley and a 3” arbor pulley, that makes it ~3910 rpm. The manual for the PM68 states the maximum SFM for a 12” blade is 13,000… with the 3.4”/3” combo, that puts it at 12,277 SFM. You could actually go with a 3.5” pulley, which might be easier to find, which puts it at 12,639 SFM (or ~4025 rpm). With the 3”/3” combo, it’s only 10,833 SFM.
Just saying :)
jbay
#12 posted 06-09-2017 08:52 PM
In my first post I said “Honestly I can tell the difference in performance.” That should have said ” “Honestly I can t tell the difference in performance.”
- AlaskaGuy
I figured that ;)
Thanks Brad,
What do you think about a 3 3/4 pulley along with using a bushing?
MrUnix
#13 posted 06-09-2017 08:57 PM
Thanks Brad,
- jbay
That might be a bit too much… it would result in a SFM on the blade of ~13,541 (~4313 arbor rpm), which is over the stated max speed in the manual.
jbay
#14 posted 06-09-2017 09:01 PM
Thanks Brad,
- jbay
- MrUnix
Thanks,
I’ll keep looking. What’s your opinion using the pulley and bushing combo?
