Designing rolling stand for Craftsman 113 table saw
Forum topic by 1tacoshort posted 06-07-2017 01:45 AM 1059 views 0 times favorited 6 replies Add to Favorites Watch
View 1tacoshort's profile
12 posts in 808 days
06-07-2017 01:45 AM
Topic tags/keywords: tablesaw stand diy
Hi all,
I’ve got a Craftsman 113 table saw and it’s on those flimsy sheet metal legs with tiny rollers on the bottom. Unfortunately, the rollers are honked up and the legs are a little bent (it’s an ancient saw), so it’s really a stationary saw that I laboriously drag around my garage. So, I’m trying to come up with a design for a stand that I can build. I’ve searched the net and for ideas (I didn’t find much for table saws) and I’ve been working on some plans but I have a few questions:
1) The sheet metal legs are about 10” wider in each direction on the bottom as they are where they join the saw so I figure a rectangular base that extends straight down from the saw would be unstable and want to fall over. Should that be a concern or would this design solution be fine?
2) The saw seems pretty heavy. Is a 3/4” plywood box, open at the front, and without supports directly under the saw going to hold the saw or (and this is my tendency—I can’t really spell “engineer” without “OVER”) do I have to engineer the crap out of the thing to make sure that it doesn’t collapse?
3) About casters: I’ve seen a lot of people in favor of four lockable swivel casters. My concern with that approach is that all the casters will be pointing back toward me after pushing the saw to its work location. That puts two casters sticking out where I can get at them and two hidden under the stand. How do people lock the casters that are under the stand? Do the get on their hands and knees and rotate those casters by hand? There has to be a better way.
4) Have I missed the ideal solution out there, somewhere (plans or, even, an aftermarket stand—I’d really rather go back to making furniture rather than stands for my shop equipment)?
Thanks, everybody!
-- Wade
View eric4716's profile
49 posts in 398 days
#1 posted 06-07-2017 02:04 AM
I am looking to do something similar for an outfeed table for my table saw. Have you considered the lifting casters that lift the stand onto the rollers until you get it into place and then drops the saw base back down onto the floor so it rests on the legs? You could mount them on the inner sides of the legs so they don’t stick out.
View martyoc's profile
40 posts in 846 days
#2 posted 06-07-2017 02:09 AM
Could you make a base with the legs fastened on top with retracting casters.
-- Marty O'C
#3 posted 06-07-2017 03:40 AM
My dad has some stands that have the lift-onto-them variety of casters. Those are pretty nifty.
-- Wade
View HokieKen's profile
4653 posts in 1067 days
#4 posted 06-07-2017 04:29 PM
I built a stand sort of like you’re looking at for my TS a couple of years ago. I don’t have any pictures of the stand specifically but, here’s the back of it:
And you can see the front in the background of these photos:
To address your concerns:
  • 3/4” Plywood should be plenty strong enough. I built mine bigger than necessary to have some storage so I put a vertical support under the saw. If mine wasn’t so wide, I don’t think it would be necessary. I also made a frame from construction lumber for the base. I think it was overkill though, I probably could have got by without the added stiffness.
  • I used four double-locking swivel casters. With double-locking casters, it’s only necessary to lock 2 to prevent movement. So I just lock whichever 2 are easiest to get to.
  • If you’re not making your stand over-sized like I did, you will want to be careful about tipping. Ideally, if you draw a straight line from the center of your saw (actually the center of mass but probably close to the same thing) to the bottom edge of the stand, it should form a 45 degree or less angle with the horizontal. However, you can get by with significantly less that that. Basically, it’s just a matter of figuring it out. You have to consider the size and weight of what you’ll be cutting, whether or not your floor is flat/level and how much force you’ll be pushing on the saw with. Another, more space-saving way to address this is to simply use the bottom of the stand for storing something heavy or put a couple of sandbags on it. That drops the center of mass close to the ground and generally eliminates any concerns of tipping.
Hope this helps some!
-- Kenny, SW VA, Go Hokies!!!
View dschlic1's profile
412 posts in 1899 days
#5 posted 06-07-2017 05:39 PM
I have a 113 saw also. I use a Harbor Freight mobile base. Works great, doesn’t cost an arm and a leg and because of how it sits on the base the sheet metal legs are braced at the bottom. I highly recommend going this way.
#6 posted 06-08-2017 04:24 AM
Thanks, guys!
-- Wade
