Delta 34-802. Unisaw?
Forum topic by firefighterontheside posted 06-07-2017 01:34 AM 921 views 0 times favorited 6 replies Add to Favorites Watch
19622 posts in 2096 days
06-07-2017 01:34 AM
What do you guys know about the 34-802? Looking at one without a motor. What motor should it have? Is it a unisaw?
Thanks in advance.
View bigblockyeti's profile
bigblockyeti
5317 posts in 1960 days
#1 posted 06-07-2017 02:00 AM
I like mine, quite a bit actually. Yes, the 34-802 is a Unisaw. Mine has a single phase TEFC 3hp Marathon motor. I have no idea how many different makes of motors but it should have been available with 3 or 5hp single phase or 5hp three phase.
#2 posted 06-07-2017 02:09 AM
The guy is asking 350 for a saw with no motor. Sounds too steep. How much is a motor.
View MrUnix's profile
MrUnix
7107 posts in 2438 days
#3 posted 06-07-2017 02:16 AM
- firefighterontheside
Figure about $300-$500 depending on where you get it. Might be able to find a used one a bit cheaper. If it has an IEC type starter, you should be good… if it has a NEMA type starter, then you may have to mess with it as well.
bigblockyeti
#4 posted 06-07-2017 03:21 AM
$350 certainly doesn’t sound cheap but might be fair if it’s in really good shape, do you have any pictures? You might be able to get a three phase motor pretty cheap and run it with a VFD offering a lot of control over what the motor can do.
MrUnix
#5 posted 06-07-2017 03:45 AM
There is a guy in St. Louis selling a 3hp single phase motor for $300, although the ad has been out there for a couple months, so it might be gone by now. You will also need to get a pulley and probably a new set of belts as well (roughly another $100). Throw in some new arbor bearings, wiring and other misc. stuff and you are looking at close to $800 or more by the time you are done. Not a bad price compared to new, but you can find complete Uni’s for that price or less that would not involve as much work.
View hairy's profile
hairy
2783 posts in 3771 days
#6 posted 06-07-2017 12:06 PM
There are 2 types of 34-802. I have a type 2. I think the dust door in the cabinet is the major difference. Mine does not have a dust door, I wish it did. I think dust collection would be better with it.
I’m not sure of the year of the change. Mine is 1989.
http://www.ereplacementparts.com/delta-34802-type-1034-tilting-arbor-unisaw-parts-c-3275_3334_14084.html
http://www.ereplacementparts.com/delta-34802-type-1034-tilting-arbor-unisaw-parts-c-3275_3334_14083.html
The guy I bought mine from spilled Coca Cola into the original 3 hp motor, and replaced it with a 4 hp Leeson. I got an old saw with a new motor, his wife stayed on his case to get a Sawstop.
-- My reality check bounced...
