Need Help - Router Bit Tearout and burning
Forum topic by Boghog posted 06-06-2017 11:52 PM 555 views 0 times favorited 8 replies Add to Favorites Watch
View Boghog's profile
Boghog
27 posts in 418 days
06-06-2017 11:52 PM
Topic tags/keywords: question maple router problem technique
Guys, I wanted to share some of my troubles this weekend…
I was attempting to cut a dove tail groove in a piece of maple.
It should look like this model… however, I really struggled with a couple different issues…
I had entry side and exit side tear out:
And at a certain point, the bit started to get REALLY hard to pass through the maple…
and I got a lot of burning like this:
I tried a bunch of different ideas including painters tape and sacrificial pieces to support the wood fibers,...
sigh this shouldn’t be this hard…
Where do i need to start looking to root cause my problem here? bit speed? dull bit?
Thanks for any/all input…
JY
-- Justin Young, Indiana
8 replies so far
View papadan's profile
papadan
3584 posts in 3274 days
#1 posted 06-06-2017 11:59 PM
Blade is dull and speed is too fast. With the angle on the side of the piece, how are you holding the wood to cut the dovetails, could be binding. Try a piece before cutting the angles above the DTs
View Rich's profile
Rich
2285 posts in 495 days
#2 posted 06-07-2017 12:04 AM
- papadan
+1 on papadan’s comment. I’ll add to clean the bit and use a backer board.
-- No matter how much you push the envelope, it'll still be stationery.
Boghog
#3 posted 06-07-2017 12:09 AM
So i don’t have a variable speed controller on my router, what speed should i be running at to improve the quality of cut?
@papadan
runswithscissors
2654 posts in 1930 days
#4 posted 06-07-2017 01:25 AM
That is a lot of wood to hog out at one pass (and of course you have no choice with dovetails). Try initiating each cut with a straight bit, wide enough to match the narrowest part of the dovetail. Then follow up with the dovetail bit. Should stay sharp longer and not create as much heat.
You could also make similar cuts with a dado on the TS.
View Madmark2's profile
Madmark2
379 posts in 493 days
#5 posted 06-07-2017 01:25 AM
Stringiness varies by material. Some is inevitable. Light sanding will fix tearout & no one will ever see the burnt sides. The burning suggests you are using HSS, try carbide instead.
M
Boghog
#6 posted 06-07-2017 01:32 AM
Great ideas guys, thanks a bunch!!!
runswithscissors
#7 posted 06-07-2017 01:39 AM
Dull carbide will burn just as readily as HSS.
View Nubsnstubs's profile
Nubsnstubs
1246 posts in 1635 days
#8 posted 06-07-2017 02:34 AM
Hog, I have a hard time with posts like this. You are concerned with burn marks made from the router bit, but the first picture of your project has burn marks above the dovetail. No concern about your saw? If it can’t be seen in the finish product, don’t worry about it. I would guess that the oils or sap/moisture in different wood species would react differently from a fast moving heat building cutting instrument and burn at different feed rates. I’m surprised that cross grain cut into hard maple only left that little tiny burn you are showing. When you have ashes instead of chips, you need to worry then.
Tearout is just something that is inherent with woodworking, especially with a router on the exit. Learn to live with it. If you can’t live with it, use a thicker piece, and trim off the tearout after the pieces are all routed. Watch out for that burn from the saw, and have some fun. ........... Jerry (in Tucson)
